Home
Downloads
Forum
Shop
News
Home
Help
Search
Login
Register
Welcome,
Guest
. Please
login
or
register
September 08, 2010, 16:23:56 pm
1 Hour
1 Day
1 Week
1 Month
Forever
Support
CamBam help (General usage)
Drawing in planes other than XY
Pages: [
1
« previous
next »
Author
Topic: Drawing in planes other than XY (Read 267 times)
Offline
on:
February 05, 2010, 22:34:08 pm »
Is there a way to tell CB that the drawing plane is the same as the view plane?
If I view XZ plane and draw, the drawn lines/arcs are still in the XY plane. I did figure that I could draw everything in the XY plane, select all, and then rotate on the X axis. However, that's awkward.
My goal in this is to be able to mill a semi-circular surface whose center is along the Y axis. Is this something realistic to be drawn in CB?
atwooddon
Offline
Re: Drawing in planes other than XY
Reply #1 on:
February 06, 2010, 00:45:13 am »
If I understand what you want correctly, you could accomplish this using the 'extrude function. Draw a semi-circle diameter you want, draw a line across the base, join the 2 lines into a single polyline. Leave the semicircle selected and then use Draw>Surface>Extrude. Enter the length you want, then select how many surfaces you want it to use. I chose 50 as a test. Now if you rotate your drawing, you will see a semicircular tube of the length you selected. Select that surface and rotate it -90 degrees on the X axis and you have a semi-circular entity laying along the Y axis with the base at zero Z.
Pages: [
1
« previous
next »
Please select a destination:
Announcements
=> Latest News
Support
=> Installation Help
=> CamBam help (General usage)
=> Problem dxf files etc...
=> Scripts and Plugin Help
=> How to's and tutorials
Resources
=> CamBam files (*.cb)
=> Scripts and Plugins
=> Post Processors (*.cbpp)
Made by CamBam
=> Members Projects
=> Members Machines
FeedBack
=> Bug Reports
=> Feature Requests
=> CamBam plus feedback
=> CamBam Shop Feedback
Loading...
