February 22, 2020, 07:36:51 am
Pages: [1] 2 3
Author Topic: I need a couple of macros please .  (Read 3352 times)
chuckeroo
« on: July 24, 2019, 16:48:09 pm »
I could use a macro for tool change position and a park position. Oh yes i would use these every time i spark this machine up.
        Thanks for the help.
« Reply #1 on: July 24, 2019, 19:07:32 pm »
Mach3 2010 screenset have those options.
 you can find it here.
http://www.thecncwoodworker.com/2010.html
chuckeroo
« Reply #2 on: July 24, 2019, 19:56:38 pm »
Thanks . I just purchased the screenset from gerry. will he send me a link thru my email?
chuckeroo
« Reply #3 on: July 25, 2019, 17:05:25 pm »
Well getting familiar with the 2010 screenset.  As far as wiring the 2 auto zero plates movable and fixed are they using the same wires basically just parrelled? The movable plate to be positioned on top of the stock?  So when the G Code stops for an M6 after zeroing it's going to the tool change position and then change the tool, then probe the fixed plate? After thinking about it park position is associated with M30 i think.And tc is a rapid to tool change position.
« Last Edit: July 25, 2019, 17:25:47 pm by chuckeroo » Logged
« Reply #4 on: July 25, 2019, 18:56:30 pm »
"As far as wiring the 2 auto zero plates movable and fixed are they using the same wires basically just parrelled?"
Yes, those plates share the same input.
"The movable plate to be positioned on top of the stock?"
Yes.
So basically, after is all set on your machine ( you need working HOMING switches only, machine must know fixed place location in relation to your homing switches, and tool change position) with tool installed when you click the(chevron looking like) icon the auto z zero process start. The z axis will move down and will go till touches moving plate, and the proceed to fixed plate.. When the new too # will be called for, the machine will park for tool change in position where you tell it to be when you set this whole thing up. After tool change, click cycle start to resume machining.. Good luck.
driedeker
« Reply #5 on: July 25, 2019, 19:32:35 pm »
If you like the 1024 screenset and would like the 2010 macros in that,
I have a edited 1024 with all those macros as I use a mill and got used to the look
« Last Edit: July 25, 2019, 20:32:00 pm by driedeker » Logged
chuckeroo
« Reply #6 on: July 25, 2019, 21:28:58 pm »
Thanks and yes i can successfully home the mill. Gonna play with it and see what happens.
chuckeroo
« Reply #7 on: July 26, 2019, 15:15:20 pm »
Driedecker that sounds interesting and yes i would like to have that. Thanks
chuckeroo
« Reply #8 on: July 26, 2019, 21:38:37 pm »
well i installed the 2010 screeenset and tried homing with less than desirable results. when attemting to home the y i had no movement on the a axis and yes they a is slaved only because i have a gantry setup. Also i cannot enter prgram limit. when auto zeroing  i get a message clearance plane must be set to zero.HMMMMMMMMMMM
« Reply #9 on: July 27, 2019, 01:13:36 am »
can you elaborate..
« Reply #10 on: July 28, 2019, 00:49:51 am »
You don't need any fancy screen set to use Macros with Mach 3.  I use macros with the ordinary 1024 screen set.
driedeker
« Reply #11 on: July 28, 2019, 09:24:10 am »
put jpg in Mach3\Bitmaps\MillBitmaps and load the screenset.
Let me know if it pans out ok.
* 1024my.zip (23.87 KB - downloaded 39 times.)
driedeker
« Reply #12 on: July 28, 2019, 10:17:40 am »
can you elaborate.. what macros?
« Reply #13 on: July 28, 2019, 16:05:21 pm »
Any ones I want.
All the screensets do is allow you to package them into a button and make it look pretty.
Machscreen (a little buggy) by Klause allows you to edit your screens as well.  Its also helps to look at things and see how they work.  Macros themselves are just little "script" files.  Many of your M Codes activate macros.
The ones I have modified on all my machines are for tool changes and end program.  M6 and M30.  My only real issue is a lack of knowledge about writing macros themselves.  I have made what I needed so far by dissecting other people's macros and figuring out what they do.
« Reply #14 on: July 28, 2019, 19:00:50 pm »
Bob  Sed:
"My only real issue is a lack of knowledge about writing macros themselves.  I have made what I needed so far by dissecting other people's macros and figuring out what they do."
Don't feel to 'inadequate' about that!  That is how almost all programmers learn about a new language.  They try a few things, they study other folks software, and they practice.
I spent a whole career doing essentially that. 'Actually got 'pretty good' at a few languages. <grin>
Pages: [1] 2 3
Page created in 0.165 seconds with 20 queries.
