April 01, 2020, 09:57:17 am
Pages: 1 [2] 3
Author Topic: I need a couple of macros please .  (Read 3592 times)
chuckeroo
« Reply #15 on: July 28, 2019, 19:51:04 pm »
I first want to thank everyone for the participation. Ok first question do i simply add  Do button(25) to add the Y axis to the A axis during homing as i have a gantry style machine cncrouterparts 48x48. Also when try to use the safe Z it pops up a box that says safe is not enabled.Come on of course i set it up in cofig and safe Z setup. And yes bob i'm like you i am simply not a programmer by any means. And yes all i wanted to install was tool change position and park position. Which i know can be accomplished from the the 1024 screenset. I did manage setting up a tool change position after reading a post on the cambam website. I still lack a park position, maybe i should do a search on this website and see what i get. I'll fiddle with them both until i get what i need.Just occured to me their is a park position macro in gerry's screenset. Hmmmmmmmmm
chuckeroo
« Reply #16 on: July 29, 2019, 16:15:36 pm »
I've read where a G28 can be placed in front of the M30 in the post processor and it would call the G28 prior to the M30 basically setup the values in G28 in mach and you have a park position? Does this sound workable?
        Thanks for the help
« Reply #17 on: July 29, 2019, 17:05:49 pm »
Of course.  G-codes and M-codes in a 'sequence' of them are executed 'in order' of occurrence on the line.
G28 would cause the machine to return to its 'reference' position, and M30 would cause a 'program end'.  It also supposedly resets the program pointer to the beginning of the existing program, so all you'd need to run it again is press 'start'.
However, it does NOT just do a program 'pause' that would allow you to move to the next codes following it.
For that, you need an M0, M1, or M60.  M60 would be my choice.
« Reply #18 on: July 29, 2019, 17:22:47 pm »
Yes, it's what I use
in the footer of the post processor:
{$clearance}
{$spindle(off)}
{$cbfile.footer}
G28
{$endrewind}
chuckeroo
« Reply #19 on: July 29, 2019, 18:15:05 pm »
Thanks David you know it doesn't sound like it would be a big help but it's 1 more thing to contribute to making this mill run smoother.I do thank you for that and i need to do some research as to why this macro was put together the way it was. Guess i'm going to learn a little bit about programming one way or the other.
driedeker
« Reply #20 on: July 29, 2019, 21:54:28 pm »
yes there is a park position in 2010 and in that 1024 screen set i uploaded.
are you wanting to park at the end of a job or on a button.
I park it at the toolchange position.
M883 macro is park macro just call that after you set the correct park co ords and safe z
Correct park co ords and safe z are dros in the screenset that you put you co/ords in.
are you using 2010 or mine or standard screenset.
« Last Edit: July 29, 2019, 23:07:04 pm by driedeker » Logged
chuckeroo
« Reply #21 on: August 01, 2019, 17:22:09 pm »
Driedecker with the info that David has provided about using the Post processor to manipulate the park position it's the option i chose.Thanks a ton anyway for your assistance!
driedeker
« Reply #22 on: August 01, 2019, 17:57:49 pm »
No probs glad your sorted.
chuckeroo
« Reply #23 on: August 01, 2019, 19:30:17 pm »
MR David, while i was in the PP i noticed tool change. Is this something that could be manipulated for the tool change position?I have got to think yes and in my case it is merely a guess.
« Reply #24 on: August 01, 2019, 20:49:14 pm »
In my case I just use a button in Mach3 (done with MachScreen ; a VB script button) with  a code like:
Code("G0 G53 Z-1")
Code("G0 G53 X-215 Y -520")
this move the axis to the machine coords (G53) I want.
This code can also be written in the toolchange macro of Mach3 if you want that the axis moves automatically when a M6 is "played"
In Mach3, you can edit the "M6start.m1s" macro and add the code you want.
It can also be done in CB with almost the same code, except that it's not VB script, so you can
write something like: (in the "Tools - Tool Change" macro of the PP)
{$clearance}
{$comment} T{$tool.index} : {$tool.diameter} {$endcomment}
G0 G53 Z-1
G0 G53 X-215 Y -520
T{$tool.index} M6
of course, the values for XYZ will not be the same as mines Wink
« Reply #25 on: August 01, 2019, 22:14:01 pm »
The 2010 screenset worked right away for me.
Among other features, it has;
* Auto zero macro for toolchanges
* Go to Toolchange position
* Go to Safe Z
* Go to Zero's
* Go to Park Position
In other words it already has as many 'go to' positions as anyone should require without using Mach3 for example.
I'm saying this because it should suit 'non programmer' users better (easier)
« Last Edit: August 01, 2019, 22:21:02 pm by EddyCurrent » Logged
chuckeroo
« Reply #26 on: August 01, 2019, 23:37:42 pm »
I bought and tried using the 2010 screenset and had problems with it. Followed the instructions. it's still stting there as a profile in mach3. when i have time i will try sorting it out until then i will use what i have on hand.
« Reply #27 on: August 02, 2019, 00:28:37 am »
The same here. That why I suggested to you Chuck..
Win 10, CB [1.0} rc 1, Mach3, ESS, G540
chuckeroo
« Reply #28 on: August 02, 2019, 16:18:35 pm »
Thanks Bubba i will work with it later on.
chuckeroo
« Reply #29 on: August 03, 2019, 00:40:33 am »
Thanks for all of the help.Got the little mill running like i need and happy with it now. Where's those proximity sensor's anyway. Last neccessity before i can start using the mill with some degree of repeatabillity. Hopefully this helps someone else too.
Pages: 1 [2] 3
Page created in 0.171 seconds with 18 queries.
