June 24, 2019, 11:54:06 am
Author Topic: Travel clearance Z height  (Read 490 times)
Nissim
« on: May 15, 2019, 04:39:15 am »
Good day
I am wondering if I can set within CamBam the travel Z height above the material.
Many thanks
Nissim
« Reply #1 on: May 15, 2019, 05:56:56 am »
Yes, it is the clearance plane value in each machining operation (MOP)
Nissim
« Reply #2 on: May 17, 2019, 04:34:50 am »
Thank you David
Your advice did the trick !!
Thank you
« Reply #3 on: May 17, 2019, 16:48:44 pm »
Also, if you want to default to a particular height you can set that in the styles library in the root style.  Then every operation will use that default height unless you change it or use a non-default style where its different.
« Reply #4 on: May 30, 2019, 21:16:54 pm »
So I do not need to increase the Z axis height in the sense that I do not need the milling bit to travel longer. I just need more clearance so I can
Could you restate the sentence in the form of a question?
« Reply #5 on: May 30, 2019, 21:54:46 pm »
Don't worry BoB, it's a spam  Wink
try is IP on stop forum spam
178.62.93.49
https://www.stopforumspam.com/search
« Last Edit: May 30, 2019, 21:56:22 pm by dh42 » Logged
Page created in 0.119 seconds with 19 queries.
