November 22, 2019, 18:12:22 pm
Pages: 1 [2]
Author Topic: Switching from "inside" to "outside" profile has no effect.  (Read 1844 times)
tambi
« Reply #15 on: June 15, 2019, 23:31:18 pm »
Thank you dear David for spending so much time with me, special thanks for the video! Great! So I learned to do it.
With the courage of the fools, I went much further than my knowledge, so I had to install it again. You do not accept the license you received, but I have 31 more starts…
Based on Lloyd August 08, 2015, 15:09:53, I wrote M3 and M5 in the post processor, but too many times in the program.
What should I do?
Thank you very much; Tambi
* 42-dh new.cb (9.62 KB - downloaded 33 times.)
* 42-dh new.nc (3.16 KB - downloaded 30 times.)
« Reply #16 on: June 16, 2019, 00:10:11 am »
With a plasma or a laser, the torch is started/stopped by the Z move ; in this case, the M3 and M5 must be located in the Start cut and End cut properties of your post processor, and must be removed from the Spindle CW and Spindle Off properties. (*)
When start cut and end cut are used, it is the Z position of the axis that start/stop the torch ; when the Z axis move below the stock surface, the torch is turned ON, and when the Z go above the stock surface, the torch is turned off.
In this case, it is not needed to ad the M3 and M5 on the Feed move and Rapid properties as on your picture.
(*) another way to do is to remove the {$s} and {$spindle} macro from the (main) MOP property, so no M3/M5 are generated by the MOP.
the "regular" script in the (main) MOP is
{$comment} {$mop.name} {$endcomment}
{$toolchange}
{$velocitymode} {$workplane}
{$mop.header}
{$spindle} {$s}
{$blocks}
{$mop.footer}
remove the {$spindle} {$s} line.
have a look on the Start cut and End cut script of the plasma Post pro to see how to set it.
The start cut contain:
( pierce height )
G0 Z5
( torch on )
M3
( plunge to cuting depth )
G1 Z{$mop.targetdepth} F{$mop.plungefeedrate}
and the end cut contain:
( torch off )
M5
( small delay - ms )
G4 P500
Hope it help ...
tambi
« Reply #17 on: June 16, 2019, 15:35:16 pm »
Dear David!
I'm very ashamed of myself; you have the circle idle! In Autocad I did not draw a circle but an ellipse in the lower left corner ... I just know how and why Huh Sorry, you were not intentional.
For the time being I am reinstalling, not having CamBamPro.lic in the folder and not accepting the license key.
Have a nice day!; Tambi
« Reply #18 on: June 16, 2019, 16:20:14 pm »
Have a look here to solve the reinstall issue;
http://www.cambam.co.uk/forum/index.php?topic=6713.msg54329#msg54329
http://www.cambam.co.uk/forum/index.php?topic=6955.msg56643#msg56643
When starting CamBam use,  'Run as Administrator'.
« Last Edit: June 16, 2019, 16:22:50 pm by EddyCurrent » Logged
tambi
« Reply #19 on: June 16, 2019, 20:16:54 pm »
You are king, dear David!
I didn't think I could do that, but now the plasma cutting is working. Indeed, you had to type the ones you proposed in the lines of the Mach3 CutViewer Start Cut and End Cut. Thank you very much!!!
(Meanwhile, I learned that "§" is not equal to "$"! Hahaha)
Unfortunately, the number of possible launches is running out. Due to Windows10 or Defender, there is no CamBamPro.lic. What's the solution? Why has it worked so far?
System master is the same...
Thank you very much again! Tambi
« Reply #20 on: June 16, 2019, 21:33:26 pm »
I don't know why your license file is not installed, but the license key number you show in the picture is wrong ; the Cambam license key is composed of 12 groups of 4 characters.
you can open the CambamPro.lic file you received by mail with a simple text editor to show the key number.
(and don't show your key on the forum if you find it !!)
tambi
« Reply #21 on: June 17, 2019, 09:32:27 am »
Dear David!
Huuuuuuurrrrrrrrrrráááááá!
Everything works for PC Windows10 Cambam0.9.8! (even the license!)
and thank you very much.
My laptop has Windows7, Cambam0.9.8 works first ...
Have a bright day for you !; Tambi
tambi
« Reply #22 on: June 17, 2019, 12:36:12 pm »
Dear David!
I already came up with laziness ...
I crossed the "CamBam 0.9.8 documentation" but I found no answer.
Usually 10-20 mm plates are cut with plasma, roughly the same setting. How do I save them? I realized that tool save settings is not good for this ...
 Grin Grin
Thank you very much! Tambi
* 2 in 1.cb (8.03 KB - downloaded 26 times.)
* 2 in 1.nc (2.89 KB - downloaded 27 times.)
« Reply #23 on: June 17, 2019, 22:14:42 pm »
I thing the better way is to:
- define a tool in the tool library that match your plama settings
- make a "CAMstyle" with the settings that are suitable for you. (the CAMstyle can contain the tool number defined in your tool library and also all other settings like target depth, feed rate, etc that are in a MOP)
http://www.cambam.info/doc/dw/1.0.0/cam/cam-style.html
tambi
« Reply #24 on: June 21, 2019, 18:39:56 pm »
Dear David!
I haven't written to you for four days. I'm not thankless, but the CamBam plasma cutter works well. Congratulations to you and the whole CamBam for the great software.
And again, thank you very much for your help.
You want a nice day; Tambi.
« Reply #25 on: June 21, 2019, 22:40:12 pm »
Good news !  Cool
Pages: 1 [2]
Page created in 0.128 seconds with 19 queries.
