February 25, 2020, 08:19:00 am
Author Topic: Mach3 - motorised knife as A axis  (Read 865 times)
« on: April 24, 2019, 01:08:58 am »
I just make some experiments (simulation) to drive a motorized knife on A axis with Mach3.
Seems to works with a basic engraving GCode made with Cambam, except that the management of arcs is buggy so a post processor with "convert to line" enabled is required (the same as for Wrapper)
Settings:
in the setting panel
- enable tangential control
- give a value for "lift angle" (perform a Z move then rotate the knife if angle is larger than the given value)
- give a value for "lift Z" (= relative Z clearance from the actual position)
- set rotation radius to 0 for A axis.
Ports&pins > motor output
- enable A axis
config > toolpath
- disable "A rotation enabled" (if not, the display will be wrong)
- enable "Use rotation for radius"
On the video, the speed is lower in the arc, it's because my settings stays the same as for my "real" 4 axis that run at 7 RPM max ... it rotate too slowly to achieve the feedrate requested ...
http://www.screencast.com/t/HwxonBGXE
« Reply #1 on: April 25, 2019, 19:11:09 pm »
Nice.  I would love to see it in operation on the machine.
« Reply #2 on: April 26, 2019, 20:36:58 pm »
I don't have one !
It's just curiosity ; I fell on a "tangential control" button on Mach3 and I was wondering what it can be ...  so I did some search and experiments Grin
« Reply #3 on: April 26, 2019, 21:46:15 pm »
I wish I could see the screencast without installing flash.. That is no go for me.
Page created in 0.109 seconds with 19 queries.
