July 22, 2019, 23:23:04 pm
Author Topic: Milling ferrous metals  (Read 710 times)
Mark81
« Reply #15 on: April 16, 2019, 14:27:32 pm »
Tried with a cheap 3 mm HSS 4-flute end-mill found in my drawer, 600 mm/min @ 13.000 rpm, 0.2 mm DOC.
Results in the attached photo.
The "smudges" you see are not due the milling process, but from manually filing away the bridges.
« Last Edit: April 16, 2019, 19:11:31 pm by Mark81 » Logged
« Reply #16 on: April 16, 2019, 18:37:27 pm »
That doesn't look so bad, sir!
« Reply #17 on: April 16, 2019, 21:43:15 pm »
Not bad at all. Practice is your best teacher, either it will work or not.. Wink
« Reply #18 on: April 16, 2019, 22:45:53 pm »
If you aren't breaking endmills you really don't know how close you are to optimum.  I took over a machining job once that I thought was going way to slow and the previous operator had already worn out 3 endmills.  I quickly broke three myself, but the fourth lasted the rest of the job and I cut nearly 2 days off the machining time!  Another job with an 1/8" endmill started at 4 minutes per part and I had 300 to do.  Broke 3 endmills and got the time down to 53 seconds, which included removing the parts from packaging.  The cool part was that at $10 per part I made $600 an hour on a mill I paid $3000 for, and they had me do another 400!
Every time the cutting edge passed through the material it wears a little.  Slow feed with lots of rubbing wears out the end mill way faster.
Page created in 0.125 seconds with 20 queries.
