February 18, 2020, 10:19:34 am
Author Topic: 3D surface, unintended plunges  (Read 845 times)
mofosheee
« on: February 10, 2019, 23:38:37 pm »
Please refer to the attached .cb.
The profile comes out as intended............ except that the bit makes unintended -z plunges (approx 0.030ish") at both extremes in the x direction.  Tried both the horizontal and vertical 3D profile method with no success.  Waterline method will not work for this part.
Any advice on how I can eliminate this behavior and improve my method is greatly appreciated.  Thank you!
* example.cb (12.19 KB - downloaded 52 times.)
« Reply #1 on: February 11, 2019, 00:27:16 am »
Can you give a picture that show the unwanted toolpaths ?
I don't see what are the "wrong" toolpath on the image I attach. (CB V1.0)
Note that you'll get better toolpath (more accurate) if you use a value of 0.02 for resolution, instead 0.2
also, CB can only manage endmill or ballnose mill but not bullnose. (bullnose give the same toolpaths as ballnose ; if you really use a bullnose, the toolpath will not be right)
edit: picture 2 is done with resolution = 0.02, picture is done with resolution = 0.2
« Last Edit: February 11, 2019, 00:38:32 am by dh42 » Logged
« Reply #2 on: February 11, 2019, 00:50:59 am »
re
also, in the horizontal mop, you use "selected shape" as boundary but no shape is selected for the boundary.
the result is: on CB 1.0 the toolpaths are cut with an heavy overflow around the shape(*) ;  on CB 0.98, no toolpaths are generated.
(*) bigger than the "Bouding box" or the "Shape Outline" setting
« Reply #3 on: February 11, 2019, 12:33:27 pm »
To see better here is sample what David is talking about..
* example_SAMPLE.cb (12.54 KB - downloaded 73 times.)
mofosheee
« Reply #4 on: February 11, 2019, 21:48:19 pm »
Hi Guys
This has been a great learning experience.   I should have stated in my original post that a 7.5" piece of wood was the material, but no matter.  I readjusted the resolution and step over which speed things up.    In retrospect, I could have done two convex side profiles.............but nothing would have been learned.
Thanks again for pointing out the error of my ways and responding to my inquiry!
Page created in 0.119 seconds with 19 queries.
