June 24, 2019, 11:48:25 am
Pages: 1 [2] 3
Author Topic: Display Object(s) Extrema in the Status Bar, "ShowExtrema" Plugin  (Read 1963 times)
« Reply #15 on: May 18, 2019, 23:26:01 pm »
Attached is a picture of both EN and FR ; on both the texts are not complete.
Win7 - 64 ultimate & CB V1 r16
« Last Edit: May 18, 2019, 23:30:02 pm by dh42 » Logged
« Reply #16 on: May 19, 2019, 00:14:07 am »
Eddy,
My guess is that the German translation is longer than the English.  In any case, I'd suspect that either the string length is not adequate for the German, or that the 'display window' is too narrow.
« Reply #17 on: May 19, 2019, 00:22:43 am »
Hello Lloyd
The problem is the same for me with EN version ; if you have a look on the picture, the english text ends with "TopLeft(2" ; (this must be "TopLeft(2D): xx.xx , yy.yy ") and all other corners info are missing.
The max overall text length seems to be the same with all languages.
« Reply #18 on: May 19, 2019, 10:38:47 am »
This is how it looks for me. (CamBam v1.0 rel.16)
And also to 12 decimal places.
Edit: It also works for me with CamBam 0.9.8
All tested on Windows 10 / 64bit
« Last Edit: May 19, 2019, 17:45:52 pm by EddyCurrent » Logged
« Reply #19 on: May 19, 2019, 13:00:04 pm »
Ok... wow!  Yours works, and nobody else's does!  Is there a setting in CB (that I've never fooled with) that controls the maximum length of a status line message?
« Reply #20 on: May 19, 2019, 14:00:49 pm »
All is well here.. Win10 64bit, CB 1.0 Rel16
« Reply #21 on: May 19, 2019, 21:13:06 pm »
It is the same
It's the same in english.
The line is cropped after the dot.
Text Size in Windows (7 64bit) is 100%.
CamBam is V1 R16
« Last Edit: May 19, 2019, 21:16:33 pm by pixelmaker » Logged
« Reply #22 on: May 19, 2019, 21:15:40 pm »
Ralf, what is you OS ?
tested on Win XP and Win 7, CB 0.98 and 1.0, and I get the same result as you on both OS ...
« Reply #23 on: May 19, 2019, 22:26:17 pm »
That's curious, the plugin act as it should in Win 10,but behaves differently in other os.. Wink
« Last Edit: May 20, 2019, 13:50:18 pm by Bubba » Logged
« Reply #24 on: May 19, 2019, 22:35:18 pm »
That's curious, the plugin act as it should in Win 10 but behaves differently in other os.. Wink
Yes, I've same kinds of problems with my plugins that sometimes are not working on W10 but works on W7 and XP ... (example, the previous version of NumMove crash on W10 but works on 7 and XP)
« Reply #25 on: May 25, 2019, 19:10:57 pm »
Visual Studio project attached, maybe you can have a play and see what the problem is ?
* ShowExtrema_VS_project.zip (11.41 KB - downloaded 7 times.)
« Reply #26 on: May 25, 2019, 19:55:52 pm »
Hello Eddy
Just tried ; unfortunately, I can't open the file (.sln) ; It said it as been done on a newer version of visual studio (I use V 2010)
edit: ah ah ! it open if i use the .csproj file ...
« Last Edit: May 25, 2019, 19:57:30 pm by dh42 » Logged
« Reply #27 on: May 25, 2019, 20:38:54 pm »
I'm on VS 2017
« Reply #28 on: May 25, 2019, 20:55:59 pm »
Nothing to do ... even with VB script in CB, the text displayed seems to be limited to 127 chars on W7/XP.
The sb.Panels[0].Text variable contain the full text, even if more that 127 chars are used, but only the first 127 are displayed as you can see on the picture with a 200 chars text.
the VB script used.
' New CamBam VBScript
sub main
    dim sb as System.Windows.Forms.StatusBar = CamBamUI.MainStatusBar
    dim tx as string
    for n as long = 0 to 199
        tx = tx & "X"
    next n
    sb.Panels(0).Text = tx
    app.log("Text length :" & len(tx))
    app.log("Text length in the bar :" & len(sb.Panels(0).Text))
    app.log(tx)
end sub
seems it's a W7/XP limitation ...
« Reply #29 on: May 26, 2019, 01:29:23 am »
Hi David.
It's a .net limitation not the os.
Dave.
Pages: 1 [2] 3
Page created in 0.17 seconds with 19 queries.
