August 20, 2019, 19:46:59 pm
Pages: 1 2 3 [4]
Author Topic: Need help to start scripting (especially automated MOP creation)  (Read 7667 times)
« Reply #45 on: December 30, 2018, 13:26:21 pm »
So don’t let my silence on your efforts discourage you!
The same here.. Grin
gmoo
Jam it !
« Reply #46 on: January 01, 2019, 15:02:59 pm »
So here´s the X-MAS Update, folks !  Grin
Added Milling direction (conventional or climb)
Enjoy the show !
* AUTO_MAGIC.zip (25.28 KB - downloaded 51 times.)
best regards
Bernhard
« Reply #47 on: January 02, 2019, 09:43:55 am »
Bernhard,
I've just tried the script, it works great but the holding tabs are 3mm high and the Target Depth is only 1.5mm.
Maybe the Tabs need to check Target Depth ?
gmoo
Jam it !
« Reply #48 on: January 02, 2019, 15:13:07 pm »
Eddy, thanks for response !
To make this little script waterproof, a lot of effort is required.
But -to be honest- I´m the greatest lazybone walking on this earth,
so I decided to make no checks.
But I will correct the demofile for the next revision.
best regards
Bernhard
« Reply #49 on: January 02, 2019, 18:25:49 pm »
Getting code to work is fun. Getting it to be foolproof is a career.
gmoo
Jam it !
« Reply #50 on: January 22, 2019, 08:02:10 am »
There´s a nice update for auto nesting.
If the definitiion layer 00 xxxxxxx contains points, they are collected to a list in order
to nest all parts. The price you have to pay for that auto-nesting is :
You´ll have to define at least one part.
(Without nesting the script is running without a part definition as usual)
Have fun !
* AUTO_MAGIC.zip (25.72 KB - downloaded 45 times.)
best regards
Bernhard
gmoo
Jam it !
« Reply #51 on: March 13, 2019, 12:15:03 pm »
I found it would be nice to set the holding tab´s width and height.
Also I figured out how to mill above z=0.
I need it to leave wood a little thicker for sanding afterwards to correct thickness.
Remember the option T will be inverted : T3 mills down to Z-3,
T-1 to Z=+1
Yes... I know... but this easier to me (I´m thinking with my stomach instead of my brain)
# 13.3.2019
# Negative Value for T results in milling ABOVE Z=0 by raising
# the stock surface to +(Value).
# Changed internals : now options longer than 1 characters are recognized
# Added new option HH (Holding Tab Height) and HL (HoldingTab Length)
Play loud !
Bernhard
* AUTO_MAGIC.zip (26.11 KB - downloaded 30 times.)
best regards
Bernhard
Pages: 1 2 3 [4]
Page created in 0.128 seconds with 19 queries.
