December 12, 2019, 19:33:26 pm
Author Topic: [V1 - 24] Transforming PolyRectangles (not a bug)  (Read 1712 times)
GeoffreyGRoy
« on: November 01, 2018, 09:19:52 am »
I know this, or a similar, bug has been previously reported some time ago in  http://www.cambam.co.uk/forum/index.php?topic=1955.msg11437#msg11437, but the bug still seems to be around.
My task involves:
(1) creating a number of Polyrectangles
(2) rotating each of them using Transform-> Rotate using the mouse, then
(3) transforming all of them (together) using the Transformation matrix
The results are shown in the attachment.  Basically the application of the Transformation matrix does not give the correct result if more that one Polyrectangle is to be Transformed.
If I first convert the Polyrectagles to Polylines, then it all works.
The first test is with a single Polyrectangle (OK), then with two (not OK), then after conversion to Polylines (OK)
Geoff
* TransformPR.pdf (402.1 KB - downloaded 75 times.)
« Last Edit: November 01, 2019, 22:50:54 pm by dh42 » Logged
« Reply #1 on: November 01, 2018, 14:33:12 pm »
In the past I've been told to tranform all the object in polylines before  applying the transformation matrix.
I guess because the transformation matrix work on polylines only.
As a side note internaly the polyrectangles XML part hold the polyline of the shape.
<rect id="4" Closed="true" p="137,67,0" w="52" h="21" radius="2">
          <ModificationCount>51</ModificationCount>
          <Tag>With corner radius</Tag>
          <mat m="Identity" />
          <pts>
            <p>139,67,0</p>
            <p b="0.41421356237309503">187,67,0</p>
            <p>189,69,0</p>
            <p b="0.41421356237309503">189,86,0</p>
            <p>187,88,0</p>
            <p b="0.41421356237309503">139,88,0</p>
            <p>137,86,0</p>
            <p b="0.41421356237309503">137,69,0</p>
          </pts>
        </rect>
« Reply #2 on: November 01, 2018, 15:00:31 pm »
I'm sure it's due to their properties, i.e. it has a point for 'lower left' then 'width' and 'height' so it looks like the transformation just uses those.
GeoffreyGRoy
« Reply #3 on: November 03, 2018, 07:47:57 am »
It seems that a single Polyrectangle transforms correctly, but  if two, or more, are selected together the problem appears.
Geoff
« Reply #4 on: November 04, 2018, 11:26:02 am »
What the problem is?
From the image it seems that the sides are not drawn correctly and somewhat "staircased", maybe the transformation is a "scaling" and internally the routine has some bug, but the fact that with one polyrectangle is working and with many polyrectangles is not it seems strange.
The problem appear to all the "entities", or maybe only to the "last selected" entity.
Maybe i go wrong but a the apply transformation "routine" has to scan the selection and apply the same transformation to all the entities, maybe a problem in the "last selected" entity could reveal a bad code in some "loop".
The problem appear only on PolyRectangles or maybe even in mixed objects like Circles (that are not Polylines).
« Reply #5 on: August 20, 2019, 21:19:04 pm »
I get a reply from Andy about this behavior.
Rectangle transformations cannot always be automatically applied.  Applying transformations means the internal representation of a shape (e.g. control points) are multiplied by the transform matrix and the transform reset to identity.
In these cases the transformation matrix is left intact and is applied when needed (such as during toolpath generation etc).
In this problem, when multiple, rotated rectangles are selected, they will each have different transform matrix properties.  The property editor will show an 'empty' value when multiple, different property values are selected.  Changing the property will change the value for all the selected objects.  When an 'empty' transform matrix property is expanded (using the [...] button), the Identity matrix is used as a default.
For multiple selections of any object types, if the objects have differing property values, unless the intention is to change this to a common value, each object should be selected in turn and the property modified.
GeoffreyGRoy
« Reply #6 on: August 21, 2019, 00:11:58 am »
Dear David
Many thanks for passing on the explanation.  I suppose the "solution" could be to either:
(a) provide a warning if multiple polyrectangles are chosen for transformation, or
(b) auto-convert them to polylines, then apply the transformation
Thoughts for the future!
regards
Geoff
« Reply #7 on: August 21, 2019, 01:48:34 am »
Saw the same kind of problem transforming concentric ovals that were polylines. One made a linear move correctly the other did not. Transformed separately worked fine.
Page created in 0.114 seconds with 19 queries.
