January 27, 2020, 07:00:22 am
Author Topic: German KOSY CNC A4 PP needed  (Read 1302 times)
facebraker
« on: October 30, 2018, 14:09:03 pm »
Hello, there,
I am using a KOSY A4 CNC, does anyone have a postprocessor settings? Huh
I want to buy the software only when the PP is working properly.
These are the manufacturer's specifications
http://www.max-computer.de/x5e/adaption-of-post-processor.html
Thanks for your support
« Last Edit: October 30, 2018, 14:11:42 pm by facebraker » Logged
« Reply #1 on: October 30, 2018, 14:18:58 pm »
Did you try it with the CamBam 'default' post processor ?
facebraker
« Reply #2 on: October 30, 2018, 14:27:06 pm »
Thank you for the quick reply.
yes i have tested the default PP, i have change some configuration which i can locate.
But now i get error which i can't narrow down.
For Example:
G0 X-76.0 Y-12.0 Z3.0 ... i get the error "Invalid movement X axis "
i was hoping someone already has a configured pp.
Greets Alex
« Reply #3 on: October 30, 2018, 14:54:36 pm »
I'm almost sure it's not the PP. Some controllers need the machine to be hardware zeroed at startup. If not, the controller assumes some axis is going out of the hardware limits and stop execution.
A friend using UCCNC told me about a bug where there are number of subsequent work zero being set at different points then the controller gave a similar error. I.e. is not keeping the right machine coordinates regardless of the working coordinates set.
P.S. either that or you have not set the correct working coordinates in CamBam. But it is not its fault.
« Last Edit: October 30, 2018, 14:56:27 pm by Dragonfly » Logged
KoenraadL
« Reply #4 on: February 23, 2019, 17:11:27 pm »
FWIW, a few years ago I had access to a Kosy-machine. First using NCCAD7, later NCCAD9. I made postprocessors that worked for me.
Please be carefull, test them first.
* NCCad7.cbpp (0.99 KB - downloaded 67 times.)
* NCCad9.cbpp (1.41 KB - downloaded 87 times.)
Page created in 0.121 seconds with 18 queries.
