November 18, 2019, 11:15:06 am
Author Topic: Machining by strata (Thick 3D model)  (Read 4642 times)
« on: September 13, 2018, 02:40:11 am »
To machine thick 3D models, it may be useful to use machining by strata .
This consists of creating strata by cutting the part into "sheets" of a more manageable thickness.
We want to cut this part into strata of 20mm high to get something like this.
It is not easy to do this cutting in a 3D soft, and it is not only necessary to slice the part but also to close the empty surfaces at the top of the cut.
All these operations can be done very simply in CamBam.
By very simple, I mean that it is not even necessary to physically cut the 3D model, we use directly the complete model.
Method 1 - moving the 3D model "through" a limited Z machining area.
In this case, only one 3D machining operation is used and a Gcode file is created for each stratum at a time.
On the image below, we see a complete machining on the whole height of 100mm. I intentionally used a single pass of 100mm depth so that the image stay clear.
The top of the model is at Z = 0 and the bottom at Z = -93.2.
In Cambam, the machining will be done between Stock Surface and Target Depht ; all that is outside these Z boundaries is ignored. The yellow box show the stock.
A Cutviewer simulation
Now, we will create a file for each stratum with minimal modifications to our file.
The principle is to limit the machining depth to 20 mm instead of 93.2 mm for the complete model.
The value of Stock Surface remains at Z=0, so we will always machine from 0 to -20 mm, it is the 3D model itself that we will move in height to generate the Gcode of each stratum.
For the first stratum, only the Target Depth has been changed from the starting file. (as well as the size of the stock which is now 20mm thick for the simulation)
Here I use the Bounding box boundary.
here is what it gives with Shape Outline boundary.
Now we move to the next stratum without changing anything in the machining operation. We simply move up the 3D model of 20mm.
Anything above Stock surface will not be taken into account for the toolpaths generation.
For this we use the alignment function: Transform / Align. (you can also use the NumMove plugin)
The X and Y axis are disabled (none) and we ask for an alignment where the top of the 3D model (upper) will be at + 20mm on the Z axis.
Our 3D model has moved 20mm to the top, and after regeneration of the toolpaths we can see on this side view that the top of the model is at 20mm above the Z=0 but that the toolpaths remain in the Z area 0 to -20
A 3D view with hidden 3D object (hidden layer) allows to better see the toolpaths.
Then we start again, but this time with a shift of 40 in Z for the part, then 60 etc.
For each stratum, remind to generate the Gcode and save it with a unique name for each stratum.
If you want 3D fasteners, just create 2 tubes with the extrusion function, then set them to -20. They must be selected with the 3D machining operation, in addition to the 3D model itself, but of course we will not move them in height with the 3D model.
In the following image, we see 2 bars completely crossing the model, and located at -20mm. We also note that they are selected in the machining operation (Primitive Ids = 2,6,7).
In order not to machine to the end of the bars acting as fasteners, it is necessary to limit the machining area. The circle (circle [8]) is used as a boundary using Boudary method= SelectedShape and the number of the shape used as a boundary in Boundary Shape Id.
For the next step, same thing ; of course only the 3D model must go up, the fasteners remain where they are.
Note: all simulations are done with a ball nose mill, which explains the "grid" of material remaining.
Method 2 - Using multiple machining operation at different strata levels then move the toolpaths for each stratum at the required Z position so the cut always start at Z=0
The principle is to create as many 3D machining operations as there are strata to cut ; the beginning of each machining operation start at the end of the other.
Example with 4 strata of 8mm.
In the first machining operation for the top most stratum: Stock Surface = 0 and Target Depth = -8, for the next stratum: Stock Surface = -8, Target Depth = -16 ... etc
the Clearance Plane remains at the same value for all machining operations (here +5)
Fasteners must also be created for each stratum; the fastener bars corresponding to the correct stratum must be selected with the 3D object for each machining operation.
Then, to distribute the 4 machining on the same plate, we can shift the toolpaths in X, Y and Z for each operation using the transformation matrix of each machining operation.
For example, the 3D mop # 1 is not shifted, # 2 is shifted x=120 y=0 z=8, # 3 is shifted x=0 y=80 z=16, and # 4 is shifted x=120 y=80 z=24 (see the "Transform" property of each machining operation)
* strata_method-1.zip (1063.48 KB - downloaded 94 times.)
* strata_method-2.zip (2708.5 KB - downloaded 93 times.)
« Last Edit: September 13, 2018, 02:46:52 am by dh42 » Logged
« Reply #1 on: September 13, 2018, 08:54:52 am »
Nice work and a lot of dedication!
Thanks, David!
nifty1a
« Reply #2 on: November 28, 2018, 11:46:05 am »
Looks good... can I ask how the 'connectors' work?
I would have thought round pins 'through' the layers for dowels would be used to align the layers?
« Reply #3 on: November 28, 2018, 21:24:31 pm »
Yes, it would certainly help when gluing the parts  Grin (I never do that in real). This can be added easily ..
« Reply #4 on: November 28, 2018, 21:50:24 pm »
Um... those 'connectors' are called "holding tabs" in CamBam.  They serve to hold the work in place until the majority of the milling is done.
In each MOp (machining Operation), you'll find a holding-tab entry, which you can modify to suit the job, including moving them around, if you don't like their positions.
« Reply #5 on: November 28, 2018, 22:09:00 pm »
@Lloyd: Holding Tabs do not exists in 3D machining ops (they exists only in Profile MOP) ; you must create them with 3D "tubes" by extruding circular or rectangular 2D shapes, then include them in the 3D shapes selection of the MOP so they are machined at the same time.
As on this pictures
Primitive ID 2, 6 and 7 are assigned to the mop ; 2 is the shape itself, 6 and 7 are the "tubes" used as tabs. Circle 8 is used as machining boundary to avoid that the tubes are cut up to their external end.
« Last Edit: November 28, 2018, 22:10:45 pm by dh42 » Logged
« Reply #6 on: November 28, 2018, 22:27:36 pm »
ACK!  I do _almost_exclusively_ 2.5D Mops.
I didn't even KNOW that holding tabs could not be applied to 3D MOps!
(With what... four or five YEARS of using this soft! <BSEG>)
« Reply #7 on: November 28, 2018, 22:34:38 pm »
You're registered since 2010 .... 8 years !!  Grin
http://www.cambam.co.uk/forum/index.php?topic=1396.msg7695#msg7695
 Wink
« Reply #8 on: November 29, 2018, 01:04:13 am »
Man!  Has it really been that long?!?!  I've done so much design under this soft, I cannot COUNT the jobs.
But... like I said... mine is almost entirely 2.5D, except for the scripts I've written to do 3D 'directly' (as in sloped holes with vertical tools).
« Reply #9 on: November 29, 2018, 02:59:40 am »
3D machining will be for retirement  Grin
nifty1a
« Reply #10 on: December 05, 2018, 13:28:42 pm »
Okay...thanks I understand now... They are 'holding tab' or 'machining' connectors, not 'assembly' connectors.
Obvious now you've explained it, I just got the wrong impression of the purpose from the word connector...I thought immediately of 'joining things back together'!!
Thanks...
Page created in 0.146 seconds with 20 queries.
