June 27, 2019, 06:04:40 am
Author Topic: Copying and pasting a MOP problem  (Read 1796 times)
GeoffreyGRoy
« on: August 26, 2018, 08:40:55 am »
I have a problem with my Slotter MOP (and I think the same problem occurs with the VEngrave MOP).  I have not been able to correctly implement the Copy/Paste functions and I get an assembly error (see attached image).
Has any one been able to do this correctly?  Help would be appreciated.
thanks
Geoff
Here is the source for Slotter (without CamBam libs)
* SlotterSource.zip (56.55 KB - downloaded 51 times.)
« Last Edit: August 29, 2018, 14:14:04 pm by GeoffreyGRoy » Logged
« Reply #1 on: August 26, 2018, 12:59:30 pm »
Hi Geoff
You need to target  .net 4.5 for CB ver1
I tried a copying and pasting few other plugins including my own.
I couldn't find the source code so couldn't check out any further.
« Reply #2 on: August 26, 2018, 18:52:48 pm »
The trocho pocket plugin seems to works well with copy/paste and copy/paste format ; maybe jk can help, or you can have a look on the source code.
http://www.cambam.co.uk/forum/index.php?topic=6209.0
I seems that something has changed on 1.0, because copy/paste that worked on 0.98 no longer works on 1.0
« Reply #3 on: August 26, 2018, 19:59:57 pm »
My bet is it's something to do with serialisation, I know very little about it but jk is the man.
GeoffreyGRoy
« Reply #4 on: August 28, 2018, 09:45:13 am »
Thanks for the tips, I will follow up with JK.
Geoff
« Reply #5 on: August 30, 2018, 02:54:01 am »
Hi
Please see attached .cs file with fixes, copypaste is working now.
Error was in logger instance of MOPSlotter class. It shouldn't be serialized but is was since whole MOP class is marked as serializeable. I've marked it with [NonSerialized] attribute.
I've made a few small fixes too:
SlotterPlugin class should really be static (no reason to have a several plugin instances).
Whole Logger class shouldn't be marked as serializeable.
Hack with priming the XML serializer () may be done just once at plugin init.
* SlotterPlugin.cs.zip (6.22 KB - downloaded 48 times.)
Page created in 0.134 seconds with 19 queries.
