January 16, 2019, 13:01:44 pm
Author Topic: [48] SOLVED - inconsistent behavior with maxcrossover distance in pocket  (Read 817 times)
« on: April 12, 2018, 03:15:25 am »
It's a bug report I have send to Andy by mail some months ago but I forgot to add it here (concerned: V0.98, V1.0 R14-1)
on the attached file, maxcrossover distance is set to 0.5 and stepover to 2 to see the problem more easily.
Sometime the tool return to clearance plane, sometime no.
on picture1, you can see that it's ok for the rectangle at the left side, but for the circle and the square, sometime the tool forgot to move to clearance.
also, on Cambam display, the Z moves to clearance (rapids) for adjacent paths are missing. (picture2)
The problem is solved on V1.0 R14
* MaxCrossover_bug.cb (4.46 KB - downloaded 26 times.)
« Last Edit: June 24, 2018, 19:36:25 pm by dh42 » Logged
« Reply #1 on: April 12, 2018, 09:18:43 am »
On circular shapes especially pocket tool path generation is affected even by the nature of the geometry object - a native circle or a circular polyline.
IMHO some of the weird results are due to the internal algorithm trying at any cost to do the final pass with the exact step over set in the MOP. Which results often in either an empty internal path or more than one pass with full tool engagement load. For that reason I, as well as many others, prefer a profile with cut width > TD. Works better. Judging by the way the trochoidal pocket MOP works it is not absolutely necessary the final step over to be exactly as defined. It should be treated as maximum allowable IMO.
Also, I personally don't like the alternating tool path order on consequent depth levels. They come as a (unpleasant) surprise after I've tried to set the best behavior on the first level.
Unfortunately we don't hear much from Andy and miss the feedback for our comments or suggestions. I am a great fan of CB and often jump to defend it from hasty criticism but this does not mean that a bilateral discussion is not necessary on issues which arise in real working conditions.
« Reply #2 on: April 12, 2018, 21:32:31 pm »
I think that currently, the better way to avoid this problem is to do the job with a pocket and the Region Fill Style set to Outside Offsets or Inside Offsets instead of Inside+Outside Offsets , then use a profile mop to finish the inside or outside than remain to do.
« Last Edit: April 12, 2018, 21:34:44 pm by dh42 » Logged
Page created in 0.091 seconds with 19 queries.
