January 16, 2019, 08:57:39 am
Author Topic: Mach3 - stop G-code execution from macro?  (Read 1460 times)
« on: March 06, 2018, 09:52:08 am »
I am trying to automate some repetitive actions to help me not doing things caused by concentration loss - like crashing the touch probe Sad
For this purpose I wrote simple G-code snippets which make extensive usage of custom macros.
There are cases when I'd like to cancel macro execution (done with simple MachMessage command) and stop further G-code execution. But can't find a way (if possible at all) to implement this. I've tried to execute M30 from the macro and tried also to execute 'Stop' button press with 'DoOEMButton' command but G-code execution continues nevertheless after macro code exits.
So I decided to ask here with so many Mach3 users whether it is possible and what I am missing.
« Reply #1 on: March 06, 2018, 10:41:42 am »
Do you think it could be because of Mach3 "look ahead" ?
Have you explored using Mach3 'Brains' rather than macros ?
« Last Edit: March 06, 2018, 10:43:18 am by EddyCurrent » Logged
« Reply #2 on: March 06, 2018, 11:20:08 am »
Brains are a 'white spot' on the map for me. But I'll have to do some learning because I got interested in Modbus application recently.
« Reply #3 on: March 06, 2018, 12:21:15 pm »
You would do something like this:
Code "G1 Z -20 F100"
While isMoving()
If (IsOutputActive(Output1)) Then
DoOEMButton(1003)
Sleep 100
End If
Wend
this is part of a probing routine
« Reply #4 on: March 06, 2018, 12:33:15 pm »
With Mach3 probing a G31 is usually used to enter the straight probing routine.
« Reply #5 on: March 06, 2018, 12:55:04 pm »
That's true eddy, I was just showing how to stop mid stream so to speak.
that ones based on using G28.1 which you can also use.
« Reply #6 on: March 06, 2018, 19:34:41 pm »
Dave, I realise that but I wondered if your code snippet still worked the same when not in a probe sequence.
« Reply #7 on: March 06, 2018, 21:27:12 pm »
I didn't use a pause  - Sleep(100) after calling  DoOEMButton(1003), maybe this is the reason because Mach3 is a bit slow reacting to those commands. Will try and report.
« Reply #8 on: March 07, 2018, 04:29:03 am »
Hi DragonFly
Yes you should use the wait.
The macros are written with a proprietary stripped down version of vb.
Page created in 0.118 seconds with 19 queries.
