February 19, 2019, 04:21:52 am
Author Topic: Optimizing F-Engrave text / what will be my toolpath?  (Read 1115 times)
spinnaker
« on: February 05, 2018, 03:03:45 am »
In the attached image what I have done was to use F-Engrave to easily produce text in a circle.
I converted the g-code to dxf and imported into Draftsight and added the circle.
F-Engrave is a really cool easy to use product the downside is it seems to be awfully inefficient.   Those numbers are made of tons of lines.   Many seem to overlap while some don't seem to be connected.  I tired converting to polylines in Draftsight but I am about as experienced in Draftsight as I am in Cambam (which is only a few weeks of exoerience Wink  )
1.   Is there an easy way to clean that code up in CamBam?
2.  Clean up or no cleanup.  What will my actual toolpath be for the numbers?
« Reply #1 on: February 05, 2018, 06:44:17 am »
The core of the problem is the conversion of g-code to shapes. You get a sandwich of various lines representing the tool movement while engraving.
The right approach is exactly the opposite - use a suitable program to make the project using real fonts, then export to DXF, conver everything to polylines, then make a MOP and generate g-code.
driedeker
« Reply #2 on: February 05, 2018, 06:56:32 am »
use arc text plugin in cambam
« Reply #3 on: February 05, 2018, 12:13:19 pm »
Or use this plugin; http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/TextOnPolyline.html
Another way entirely within CamBam is to;
1. Draw the circle
2. use 'Text' to make the numbers
3. use Edit->Transform->Rotate, on each number
4. move each number into position
There are some stick fonts here; http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/stickfonts.html
and you would use an 'Engrave' MOp
If you want better looking fonts then use any Truetype font listed in the Text dropdown and use this plugin to cut them; http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/Vengrave.html
« Last Edit: February 05, 2018, 12:23:03 pm by EddyCurrent » Logged
Page created in 0.105 seconds with 19 queries.
