January 16, 2019, 12:36:55 pm
Author Topic: Initial Ubuntu Installation Issues  (Read 3465 times)
skyking
« on: January 25, 2018, 14:45:57 pm »
Just completed my first CNC Router Build and now trying CamBam. Retired IT with extensive Linux.
Installed 64-bit apps and system files into default directory (CamBam plus 1.0) but changed to CamBam-plus-1.0 so I don't have to put single quotes in path when creating app menu entry or desktop link.
Starting CB gives usual license popups.
Tried to change path in setup but when I save settings I get 'Error Reflecting Style CamBam.CamBamConfig'
Created a circle but there are no styles (Style "" Not Found)
and 'Style Library Standard-mm not found' and there are no Tool Libraries found either (these exist in the default directory after install though)
So I can't save settings or load libraries.
Seems to be a path problem
« Reply #1 on: January 25, 2018, 14:53:56 pm »
Look in
Tools >> Options
Switch to advanced.  Make sure the system path is correct.
« Reply #2 on: January 25, 2018, 15:42:10 pm »
You have to download the archive with the additional files and copy them to ~/.config/CamBam1.0
http://www.cambam.co.uk/downloads/dw/CamBam1.0-mono.system.tgz
Those are the files which reside in' \Documents and Settings\All Users' in Windows.
skyking
« Reply #3 on: January 25, 2018, 16:22:46 pm »
Ah, OK moved system files from app directory to .config directory.
Still can't save config get Error Reflecting Type CamBam.CamBamConfig
I don't get Style errors now and I can select tool # from dropdown.
« Last Edit: January 25, 2018, 16:29:25 pm by skyking » Logged
« Reply #4 on: January 25, 2018, 17:30:56 pm »
Perhaps you are missing some Mono libraries.  If you start CB from terminal perhaps you will see some error messages about it.
This is a quick and dirty script I use to install Mono for CB
#/bin/bash
sudo apt-get install mono-runtime
sudo apt-get install libmono-system-windows-forms4.0-cil
sudo apt-get install libmono-system-web4.0-cil
sudo apt-get install libmono-system-design4.0-cil
sudo apt-get install libmono-system-numerics4.0-cil
sudo apt-get install libmono-system-xml4.0-cil
sudo apt-get install libmono-system-xml-serialization4.0-cil
sudo apt-get install libmono-microsoft-visualbasic10.0-cil
sudo apt-get install libmono-microsoft-visualc10.0-cil
skyking
« Reply #5 on: January 26, 2018, 00:02:07 am »
OK had to install two missing mono pkgs, CB now modifies and saves config no errors.
Thanks!
Page created in 0.111 seconds with 19 queries.
