November 20, 2018, 00:46:49 am
Author Topic: Lost options in my machining tab  (Read 851 times)
edhegreness
« on: January 12, 2018, 18:14:38 pm »
Not sure how this happened. I restarted my computer the other day and opened cambam and immediately I noticed the background of the work plane was a different color than usual. I know you can change all of this easily to your preferencese but I thought it was odd as I had not made any changes other than restarting my computer.
Everything else seemed normal about my cambam setup until I chose machining options. In my Machining settings I have lost some of my settings? For example there is no clearance plane setting?
I opened a previosly made Cambam file of mine and clearance plane was there in the settings - but I was missing other options in the settings for my machining. Almost seemed like any that I had not set where no longer there?
IDk - maybe I need to reboot my Cambam. Thanks for any help. Really hoping to get this sorted out ASAP.
« Reply #1 on: January 12, 2018, 20:27:01 pm »
User settings are stored in a .config file, the location on my PC is here,
C:\ProgramData\CamBam plus 1.0\CamBam1.0.config
It may be that something prevented CamBam from opening it at startup ?
Templates are also stored in the same directory, C:\ProgramData\CamBam plus 1.0\templates
so it could be there is a problem accessing that main folder. (C:\ProgramData\CamBam plus 1.0)
Note: If you use version 0.9.8 the path will be, C:\ProgramData\CamBam plus 0.9.8
« Last Edit: January 12, 2018, 20:31:55 pm by EddyCurrent » Logged
lernincnc
« Reply #2 on: January 12, 2018, 21:13:59 pm »
If "Advanced" is showing at the top of the settings dialogue box then you are in "Basic" mode.  Click on "Advanced" and you should get all of the settings including "clearance pane".  Hope this helps.
edhegreness
« Reply #3 on: January 13, 2018, 04:22:39 am »
In the settings tab I can toggle between advanced and basic and neither shows clearance plane option. I will try and check the config file is there... seems odd though nothing should have changed
Page created in 0.096 seconds with 19 queries.
