January 18, 2019, 03:18:03 am
Author Topic: Mach 3 Question  (Read 2274 times)
chuckeroo
« on: January 02, 2018, 20:26:59 pm »
Is there a way to get Mach 3 to turn on my power supply to my steppers via a relay on the 110 side of the power supply? If so then how.
                                  Thanks and have a good day!
« Reply #1 on: January 02, 2018, 20:46:48 pm »
There is but not in a straightforward way. One could wire a relay, driven by a transistor (or a SSR - solid state relay) to the 'Enable' signal on the BOB (Break Out Board). 'Enable' is used to activate/deactivate the stepper drivers. When disabled power to motor windings is cut off. Usually this signal deactivates them when you press the red 'RESET' button on Mach3 screen or an external e-stop signal is received.
Bear in mind that disabling the drivers or cutting their power as a whole while working on an active job will make the steppers lose their microstep position and return to a fixed steady one defined by the magnet core - drive screws will make some tiny movements. Therefore a small but certain error will be inserted into the current working position of the machine.
Stopping the machine while working by clicking the red 'RESET' will also invalidate the position as some of the driving pulses to the steppers, already sent into the queue will be lost.
chuckeroo
« Reply #2 on: January 02, 2018, 21:22:01 pm »
I never thought about that.Sure it'll work and  i understand what you mean about the mill getting a little lost  because the motors have no voltage to brake them. This is correct right? I like it!
« Reply #3 on: January 02, 2018, 22:44:27 pm »
That's correct.
chuckeroo
« Reply #4 on: January 02, 2018, 23:55:57 pm »
 I came up with Crydom SSR D1210. Hoping this may sort this out. This SSR is made  for AC applications on the output . 3 to 32 volt dc input.
« Reply #5 on: January 03, 2018, 12:39:06 pm »
Just in case I report my experience with SSR.
Not to behave like an electrical engineer, as I'm only an Hobbyst but I've used two SSR that were named to be very faulty (FoteK brand) but with the correct dissipator they behave very well and they handle my 1.1KW spindle and 220V AC and my shopVAC 800+800W (two motors) at 220VAC.
So the correct dissipator is necessary, mine are 5 times taller than the SSR itself, so the gain in space is not a must with an  SSR.
As a final note I have used them with a small transistor driven by my arduino output and tied to my 24V DC supply.
chuckeroo
« Reply #6 on: January 03, 2018, 13:54:56 pm »
In my case the manafacturer is International Rectifier . Iv'e never heard of Fotek brand . And yes i agree with you the right heat sink and some heat sink grease you should get some life out of the SSR. Provided you stay in acceptable ranges .
« Reply #7 on: January 03, 2018, 14:18:43 pm »
Even better if the SSR control input is TTL logic compatible - easier to connect to the BOB. Even better if they have an opto coupler at the input for maximum insulation from the high voltage part.
« Reply #8 on: January 03, 2018, 14:53:12 pm »
fotek is a honk kong brand and as usual the SSR have an optosiolated input see the schematics of my SSR as included images, The output remind me the old TRIACs.
« Reply #9 on: January 03, 2018, 15:40:45 pm »
AC commutating SSR are triacs actually, with a zero cross detection command circuit.
« Reply #10 on: January 03, 2018, 17:23:39 pm »
Something to warn about SSRs. Common failure mode is shorted ON! The one for my heated printer bed nearly destroyed it failing that way.
« Reply #11 on: January 03, 2018, 17:31:25 pm »
I'm using the SSR as well. So, what would stop the damage to other components? A diode in line ?
« Reply #12 on: January 03, 2018, 18:17:28 pm »
A fuse, depending on the particular usage.
« Reply #13 on: January 03, 2018, 18:22:21 pm »
Oh, OK. Didn't think of it.  Embarrassed
chuckeroo
« Reply #14 on: January 03, 2018, 21:41:09 pm »
Boy does he have a point about the fuse.Sometimes i can't see the forest for the trees . yes a Triac makes sense since they are dedicated to ac switching. Well i did find something that may be of interest but not sure .In a case that i saw an M80 and M81 are used to turn on and off an atx power supply. i wonder if i could use this.Sure would like a little insight from someone more knowledgable  than me. I have no idea if this list is common knowledge or not but maybe it'll help someone.
https://softsolder.com/2013/03/14/g-code-and-m-code-grand-master-list/
« Last Edit: January 03, 2018, 22:12:53 pm by chuckeroo » Logged
Page created in 0.153 seconds with 19 queries.
