January 16, 2019, 08:54:26 am
Author Topic: [Mach3] Setting up 201 x's for the first time  (Read 1128 times)
chuckeroo
« on: October 01, 2017, 16:28:31 pm »
I have velocity setup at 375 on all axis's. Acceleration setup at 20 and step and pulse setup at 3.Since i have no clue  as to what i'm doing is this acceptable for long term use or should i make some changes?Running pretty fast and stopping on a dime .Can i push on it even further?   Thanks for any and all input!
Oh yes and why is it maxxing out at 375 on the velocity setting?
« Last Edit: October 01, 2017, 17:17:01 pm by dh42 » Logged
« Reply #1 on: October 01, 2017, 16:44:23 pm »
What software are you talking about ? Mach3 ?
Velocity and acceleration are dependent of your mechanics & motors.
On my BZT PFE500PX, velocity is set to 8000mm/min (315 IPM) and acceleration is set to 500mm/s² (19.Cool for XY (velocity = 2500mm/min for Z)
The step & pulse setup is dependent of your drivers, on mine, only 4 is working for both (M542)
chuckeroo
« Reply #2 on: October 01, 2017, 17:03:05 pm »
Ah yes i am talking about mach 3 i realize now i put this in the wrong place.Sorry!! Well anyway why is mach 3 limiting me to a maximum of 375 for velocity? Looks like i need to do some more reading about gecko 201x as far as step and pulse setup.
« Reply #3 on: October 01, 2017, 17:16:43 pm »
The max velocity is depending of the step per of an axis and the kernel speed that is set for the kernel. (at least with // port)
If you increase the kernel speed (Mach3 must be re started) higher velocity can be reached. (or if you decrease step per)
chuckeroo
« Reply #4 on: October 01, 2017, 20:34:33 pm »
Thanks that does clear up 1 detail that was just bugging me.
Page created in 0.094 seconds with 19 queries.
