January 22, 2018, 23:52:25 pm
Author Topic: Extrude Solids  (Read 1103 times)
« on: August 26, 2017, 00:30:36 am »
I just finished a new little plugin that allow to extrude any 2D shape to do a solid 3D object (with cover at both ends)
For CamBam V1 only
http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/ExtrudeSolids.html
« Last Edit: August 26, 2017, 00:39:23 am by dh42 » Logged
« Reply #1 on: August 26, 2017, 08:15:45 am »
Now that's a good one David !   Grin
We already had 'Extrude' but it did not close the top and bottom and only worked on some entities.
« Reply #2 on: August 26, 2017, 22:03:00 pm »
Not a big job, Andy do all the difficult things ! , like an extrude function with caps at both ends, He just forgot to add it in the menu  Grin
I also play with the other extrude functions to try to do tapered extrusion, but the taper arg seems to have no effect  Huh
« Reply #3 on: August 26, 2017, 23:50:10 pm »
The code
Imports CamBam
Imports CamBam.CAD
Imports CamBam.UI
Imports CamBam.Util
Imports System.Windows.Forms
' extrude solids
'for cambam V1 only
' dh42 08/2017
Public Class MyPlugin
    Public Shared Sub InitPlugin(ByRef ui As CamBamUI)
        Dim mi As New ToolStripMenuItem()   'the new menu entry (item)
        mi.Text = "Extrude Solids"
        '-------------------- menu placement test for main menu----------
        Dim mnuDraw As ToolStripMenuItem
        'search for the index of the "surface" item  in the "Draw"menu
        For n As Integer = 0 To ui.Menus.mnuDraw.DropDownItems.Count - 1
            Try
                mnuDraw = ui.Menus.mnuDraw.DropDownItems.Item(n)
                If mnuDraw.Name = "mnuDrawSurface" Then
                    mnuDraw = ui.Menus.mnuDraw.DropDownItems.Item(n)  'get a pointer to the 'surface' item in the draw menu
                    mnuDraw.DropDownItems.Add(mi)    'add the new entry at the last position in the sub menu.
                    AddHandler mi.Click, AddressOf plugin_clicked   'add a handler that call the sub 'plugin_clicked' if the main item his hit.
                    Exit For
                End If
            Catch ex As Exception
            End Try
        Next n
    End Sub
    Public Shared Sub plugin_clicked(ByVal sender As Object, ByVal e As EventArgs)
        Extrude_Solids()
    End Sub
    Public Shared Sub Extrude_Solids()
        Dim unit As Long
        Dim tp As String    'entity type
        Dim p As Polyline, r As CamBam.CAD.Region, c As Circle, a As Arc, tx As MText, sp As Spline, s As Surface
        Dim reg_array() As CamBam.CAD.Region    'an array of regions that will contain MText explode
        Dim res As Double = 0.02
        Dim rep As String, tic As Double
        Dim bottcap As Boolean = True   'used to know if a bottom cap is nedeed or not, if tickness = 0, no bottom cap to avoid double sided plane
        'test units to define a suitable resolution
        unit = CamBamUI.MainUI.ActiveView.CADFile.DrawingUnits
        If unit = 1 Then 'inch
            res = 0.02 / 25
        Else
            res = 0.02
        End If
        If CamBamUI.MainUI.ActiveView.SelectedEntities.Length <> 0 Then 'something is selected
            rep = InputBox(TextTranslation.Translate("Thickness: "), TextTranslation.Translate("Extrude Solids"), "0")
            If rep = "" Then Exit Sub 'cancel
            tic = Val(rep)
            If tic = 0 Then 'if no deep, the bottom cap is ommited
                bottcap = False
            Else
                bottcap = True
            End If
            'undo
            CamBamUI.MainUI.UndoBuffer.AddUndoPoint("Extrude Solids")
            CamBamUI.MainUI.UndoBuffer.Add(CamBamUI.MainUI.ActiveView.CADFile.ActiveLayer.Entities)
            CamBamUI.MainUI.ActiveView.CADFile.Modified = True
            For Each ent As Entity In CamBamUI.MainUI.ActiveView.SelectedEntities
                tp = ent.GetType.ToString
                Select Case tp
                    Case "CamBam.CAD.PolyRectangle", "CamBam.CAD.Polyline"
                        p = CType(ent, Polyline)
                        If p.Closed = False Then
                            p.Closed = True
                        End If
                        s = CAD3DUtils.Extrude(p, res, tic, True, bottcap)
                        s.DisplayEdges = True
                        CamBamUI.MainUI.ActiveView.CADFile.Add(s.Clone)
                    Case "CamBam.CAD.Circle"
                        c = CType(ent, Circle)
                        p = c.ToPolyline()
                    Case "CamBam.CAD.Arc"
                        a = CType(ent, Arc)
                        p = a.ToPolyline()
                            p.Closed = True
                        End If
                    Case "CamBam.CAD.MText"
                        tx = CType(ent, MText)
                        reg_array = tx.ToRegions    'explode MText to regions
                        ' make surface with each region stored in the array
                        Try
                            For n As Long = 0 To UBound(reg_array)
                                s = CAD3DUtils.Extrude(reg_array(n), res, tic, True, bottcap)
                            Next n
                            ' just in case the array is empty
                        End Try
                    Case "CamBam.CAD.Spline"
                        sp = CType(ent, Spline)
                        p = sp.ToPolyline(res)
                            p.Closed = True
                        End If
                    Case "CamBam.CAD.Region"
                        r = CType(ent, CamBam.CAD.Region)
                        s = CAD3DUtils.Extrude(r, res, tic, True, bottcap)
                    Case Else
                End Select
                CamBamUI.MainUI.ActiveView.RefreshView()
            Next ent
        Else
            MsgBox(TextTranslation.Translate("Please select at least one drawing objects"))
        End If
    End Sub
End Class
« Last Edit: August 26, 2017, 23:57:29 pm by dh42 » Logged
« Reply #4 on: October 15, 2017, 10:27:49 am »
Loaded and seems to work on v.10 - Linux
CSONNECK
« Reply #5 on: October 16, 2017, 19:46:37 pm »
Thank you
Excellent
A+
« Reply #6 on: November 17, 2017, 08:35:41 am »
Is this now included in CamBam 1.14.3 and we don't need the plugin now ?
I ask because there is a new sample file called, gear-script.cb
It has solids with closed ends and this code in a script entity,
this.Entities.Add(Solids.ExtrudeSolid("sun-gear",extrude_depth,0.1))
« Reply #7 on: November 17, 2017, 18:57:33 pm »
Not exactly, it's a python script that is used with the Script objects only. It's "Solid.py" in the script folder.
« Reply #8 on: November 18, 2017, 11:55:13 am »
Thanks, I should have known that   Embarrassed
Page created in 0.146 seconds with 18 queries.
