July 16, 2018, 18:45:38 pm
Author Topic: Problem with corner overcut and fast moves - Bug ? option True/False not working  (Read 975 times)
pdussart
« on: August 01, 2017, 08:50:41 am »
Sir,
Please find in attachement a cb file, two drawings showing the issue, the related nc file.
I am trying to cut a profile without corner overcut. The corner overcut option does not seem to work. The cut path is identical with option False and option True. The cut should always remain Outside the profile.
On the attached drawings, the cut path seems weird: there cutting lines are crossing each other, while I assume they should be simply joined. The lower corners show fast moves that could be dangerous and break the mill.
Regards, Philippe
* Chassis 2m40 universel M04 cut for CAMBAM B.nc (1.23 KB - downloaded 65 times.)
« Reply #1 on: August 01, 2017, 09:19:14 am »
I can only see an nc file
pdussart
« Reply #2 on: August 01, 2017, 09:35:22 am »
Dear,
issue resolved: some lines of the external profile were not part of a single polyline. If all lines and curbs are joined in a single polyline, it works
Regards, Philippe
Page created in 0.192 seconds with 19 queries.
