April 04, 2020, 00:15:01 am
Pages: 1 [2] 3
Author Topic: Break Edges Plugin  (Read 11328 times)
« Reply #15 on: August 08, 2017, 22:21:46 pm »
Hi Eddy
Just off to scrape the saddle dove tails on the lathe (been at for three days now), so I'll have a good look sometime this afternoon when I'm satisfied that I can't do any better. (they were on close inspection really terrible).
« Reply #16 on: August 08, 2017, 22:36:51 pm »
Dave,
Does anyone do scraping these days ? coincidentally I was ratching (http://www.cumbriandictionary.co.uk/#R)
through an old tool box of mine and came across some scrapers, last used on white metal bearings at a power station.
These days I need unfeasible amounts of light, what looks great in the shed, looks terrible in daylight  Huh and I have a good amount of 'daylight' tubes in the shed. The problem I  think is cataracts  Angry
« Last Edit: August 08, 2017, 22:46:37 pm by EddyCurrent » Logged
« Reply #17 on: August 08, 2017, 22:55:22 pm »
HI Eddy
Yes Eddy I have scrapers for textile machines "6 inch white metal bearings" , had to do the lathe as on close inspection
the dove tails look like they were done at five minute to knock off time on a Friday before someones big night out.
I've just added more lights over the welding table and  even with glasses I couldn't see the weld puddle and my helmet is auto darkening but not adjustable (big mistake) .
« Reply #18 on: August 08, 2017, 23:18:52 pm »
Sigh, I remember it well  Cheesy
« Reply #19 on: August 08, 2017, 23:26:17 pm »
Thanks for the link, got a laugh, and unbelievably new a few words (chunder for example Ha Ha).
Right I'm of to the shed to attack the dove tails (had to make a small scraper using some HHS inserts) which seems to holding up well.
« Reply #20 on: August 09, 2017, 01:56:53 am »
Dave,
Eddy,
I had cataract surgery about 6 years ago after putting it off for 3 years after being diagnosed. I had defractive cataracts. Sitting at a traffic light I could clearly two red lights side by side about one diameter apart, with one eye closed! I had given up reading at night and the final straw was getting lost up in Canada because I couldn't read any signs. Results were very good, but lots to think about before getting it done. Happy to talk about if you are interested.
Back to the originally scheduled program.
« Reply #21 on: August 12, 2017, 04:48:17 am »
Hello Dave Wink
I just try the plugin for the first time and I get an error if no style is selected.
Also, maybe because I use 120% for text size in Windows settings (W7), I get a bad display in the plugin. (and the list of tools is not sorted by tool number)
« Reply #22 on: August 12, 2017, 08:13:14 am »
Hi David
Here's a new one with more error checking and more translation and a few tooltips.
Edit Here's one that has a sorted tool list.
I don't know how to set the display to update for larger fonts, I'll have a look around.
« Last Edit: August 13, 2017, 02:30:00 am by dave benson » Logged
« Reply #23 on: August 13, 2017, 02:29:34 am »
HI All
Here's one that checks for an un-selected style as well as translations and hopefully automatically adjusts for different zoom levels.
I will leave this version at the first post as well.
* Break Edges.zip (14 KB - downloaded 157 times.)
« Reply #24 on: August 13, 2017, 02:55:27 am »
Hello Dave
Thanks Wink I'll have a look tomorrow .. now it's bed time (Exceeded by 5 or 6 hours  Grin)
« Reply #25 on: August 13, 2017, 12:56:29 pm »
Hi All
While I was testing the plugin recently I discovered something that users of Camotics should be aware of when simulating their code (not just with this plugin but simulating in general).
I have my style and tool libraries organised like this:
End-mills in an End-mill library.
Drills in an Drill Library.
V cutters in an V cutter library. soon
And so, I can have an end-mill with the same tool number as a Drill from the Drill library.
However Camotics expects a unique number for each tool regardless of which tool library it's from
and won't simulate properly.
So if you are using Camotics to simulate your code then you must have a unique tool number for each tool regardless of which library it's in.
So I've written a small tool (separate plugin) to rename all of the tools in all of the tool libraries on my system and now the simulation works the way I expect it to.
There's no hurry, David whenever you can.
« Reply #26 on: August 13, 2017, 18:42:14 pm »
Hello Dave
- it's a little better for texts size in horizontal direction but too few space in vertical direction ;(space between the objects)
- selected style (and library) say: (optional), but if select no style or no library the plugin won't.
- if you select a style library, then change for another (without closing the plugin window), each time you change the library, each time the styles of the library are added to the style list ; that cause an error if you select a style that do not match the selected library. (no pb with the tool lib)
- after the plugin as been run, the selected shape ID is not added to the created MOP
« Reply #27 on: August 14, 2017, 10:45:28 am »
Hi David
This should do the trick.
Just found one more thing, if you are using centimeters or thousandths the plugin would not account for this + updated the versioning.
* Break Edges.zip (14.3 KB - downloaded 147 times.)
« Last Edit: August 14, 2017, 11:40:00 am by dave benson » Logged
« Reply #28 on: August 14, 2017, 17:27:50 pm »
Hello Dave,
Please can you provide the source code?
There are other people who will like it too.
« Last Edit: August 14, 2017, 17:32:29 pm by BR52 » Logged
« Reply #29 on: August 24, 2017, 12:46:54 pm »
Changed the way mops are inserted into the doc.(the proper way) thanks ILspy.
* Break Edges.zip (14.26 KB - downloaded 138 times.)
Pages: 1 [2] 3
Page created in 0.363 seconds with 18 queries.
