January 23, 2018, 19:39:11 pm
Author Topic: A plugin idea (sphere)  (Read 862 times)
« on: July 27, 2017, 13:13:09 pm »
I am too far behind in terms of programming and being into CamBam API to try it myself. And there are already plugins which do almost what I have in mind but not completely. And ... there actually may exist a tool I have missed which does it.
Here is the idea: Using a tool with a spherical head (not ball nose but a sphere with a stem) to mill a sphere with a stem, i.e. go below the middle and do a spherical undercut as far as the tool geometry would allow. Both convex and concave spherical shapes. The reason for this is that I want to make a kind of ball joint.
Is it doable and anyone (Eddy I mean you Wink ) willing to give it a try?
Here is a small graphical representation.
« Last Edit: July 27, 2017, 13:16:39 pm by Dragonfly » Logged
« Reply #1 on: July 27, 2017, 13:18:07 pm »
I would use a lathe  Cheesy or a 4th axis
« Reply #2 on: July 27, 2017, 13:22:28 pm »
Me too if I only had them Smiley
Your Profile2Helix plugin is almost there.
P.S. Even with a lathe and 4-th axis internal cavity would not be that easy IMHO.
« Last Edit: July 27, 2017, 13:24:12 pm by Dragonfly » Logged
« Reply #3 on: July 27, 2017, 13:38:08 pm »
I was playing with a vertical plugin for use with a large diameter winged cutter but the problems kept mounting up. Time is not good at the moment to revisit that.
Is CamBam Lathe no use ? I've never looked into it deeply enough to know.
« Last Edit: July 27, 2017, 13:45:12 pm by EddyCurrent » Logged
« Reply #4 on: July 28, 2017, 01:58:36 am »
We the profile2helix plugin all the time with a winged rounded edge cutter to cut flanges with a curved undercut much deeper than you show. A ball would be really easy. We draw the part profile, offset the line by the tool nose radius, then move that line over in X by the tool radius of winged cutter center line. Then generate the helix and use engrave.
« Reply #5 on: July 28, 2017, 09:05:18 am »
I have tried with only a semi-circular profile and didn't get the desired result. But did not guess to make a profile like in Eddy's example. Will give it a try.
« Reply #6 on: July 28, 2017, 09:19:40 am »
I tried to reproduce the profile from the picture by Eddy but got only the top hemisphere. The helix stops at the equator.
Are we talking about the same plugin?
Page created in 0.117 seconds with 18 queries.
