May 25, 2019, 02:07:22 am
Pages: 1 [2]
Author Topic: Can CamBam carve images from photos?  (Read 3840 times)
« Reply #15 on: July 17, 2017, 20:10:11 pm »
Bill,
A region is used where there are 'islands' inside a pocket area.
From the manual;
"A region consists of a closed outer shape and a number of internal holes."
The bitmap was told to have a depth of -3 when it was imported using Draw->Surface->From Bitmap however it only managed -2.96470594406128 so there was a slight mismatch between the bitmap base and the Pocket MOP (set to -3)
So I used this plugin; http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/NumMove.html
to move it down to precisely -3 mm. Now there should be no difference between bitmap and the Pocket depth.
The toolpath colours have different meanings and these can be found/changed in Tools->Options.
« Last Edit: July 17, 2017, 20:15:02 pm by EddyCurrent » Logged
« Reply #16 on: July 17, 2017, 21:02:04 pm »
Blue toolpath are straight toolpath (G01) and green toolpath are arcs (G02 / G03)
huntleybill
« Reply #17 on: July 18, 2017, 02:45:05 am »
Ahhhh...ok. That explains it. Thank you for the explanation. So far, I'm really liking the program!
Also downloaded CamBam 0.9.8 documentation. Got a lot of reading to do!
« Last Edit: July 18, 2017, 02:54:06 am by huntleybill » Logged
Pages: 1 [2]
Page created in 0.137 seconds with 19 queries.
