February 17, 2018, 19:19:57 pm
Author Topic: Cam bam not responding (more likely windows)  (Read 996 times)
Terminal_Crazy
« on: April 17, 2017, 19:08:30 pm »
Just tried to run cam bam. 1.0a11 which I've used since it came out.
After every click I get a cam bam not responding message and then the circular hourglass.
Shortly afterwards it responds.
I've just installed 1.0a12 but still get the same.
Any suggestions please.
Mitch
Mitch
« Reply #1 on: April 17, 2017, 19:22:25 pm »
Maybe you can try to reset the default settings
http://www.cambam.co.uk/forum/index.php?topic=6491.0
Terminal_Crazy
« Reply #2 on: April 17, 2017, 21:40:13 pm »
Ok thankyou, I'll try that tomorrow.
I downloaded and tried the newer 1.0a12 with the same results.
I have downloaded and retried 0.98p and that seems to working fine so I've no idea what's caused it.
Mitch
Mitch
Terminal_Crazy
« Reply #3 on: April 17, 2017, 21:57:15 pm »
Ok just tried that.
Had to reload my license no.
Problem still present.
Mitch
Mitch
« Reply #4 on: April 17, 2017, 22:09:58 pm »
it was working and it suddenly stop working ?
Try to run CB in GDI mode.
to do that, dbl click on the shortcut icon, then immediately after, hold down the shift key until CB is finished to load.
If GDI mode has been selected by this way, you will get the following message in the log window.
Shift key pressed. Starting CamBam in GDI mode
If that works in GDI mode, there is a pb with graphic mode or VGA drivers.
What OS are you using ?
« Reply #5 on: April 18, 2017, 00:20:08 am »
What OS running in your PC? Did CB start acting up after recent changes in your computer, software update, etc...
My 2
Page created in 0.115 seconds with 18 queries.
