August 18, 2018, 19:19:33 pm
Author Topic: cambam wont join lines so i cannot profile my gear  (Read 2372 times)
fourchette
« on: April 17, 2017, 10:46:00 am »
I am a happy cambam user (CamBam.CAD : 0.9.5729.19316)
Everynow and then, the various CAD tools i use produce lines that aren't joined. That is typically the case for FreeCAD 2D projections.
In that case, i just CTRL+A everything in cambam, then CTRL+J the lines/polylines/whatever, enter 0.1 as tolerance and tadaaaaaa... i ended with a single closed polyline that i can later profile (cut basically).
Instead of 3D print a 12 tooth gear -- because basically i want it more precise and more durable -- i want to cnc mill it in delrin plastics for once.
So i did as usual, extracted my FreeCAD 2D plan as dxf, open it in cambam, select everything...
but unfortunately, this time i end with several "polyline", and -- i guess -- therefore i end up with an unusable profile output :
From freecad, I tried to output as svg, then open in Inkscape, then "Combine" (CTRL+K) all lines, then save as DXF => to no avail, same problem
any idea anyone ?
* sun_12teeth.dxf (86.91 KB - downloaded 87 times.)
« Reply #1 on: April 17, 2017, 12:34:37 pm »
Did you took the time and research this forum on how to proceed with open polylines?
This should help you.
http://www.cambam.co.uk/forum/index.php?topic=1624.0
« Reply #2 on: April 17, 2017, 13:12:20 pm »
Several issues.
1) outline consists of splines.  Convert to polylines.
2) Every resulting polyline has duplicate segments.  Explode and remove overlaps.
3) Join.
Attached file is version 1
* sun_12teeth.cb (57.47 KB - downloaded 76 times.)
« Reply #3 on: April 17, 2017, 17:37:40 pm »
A video in attachment
You know that CB have a gear generator ?
http://www.screencast.com/t/KxBWDXkO
more video here
http://www.atelier-des-fougeres.fr/Cambam/Aide/Video_list.html
* 2017-04-17_1834.rar (1447.52 KB - downloaded 77 times.)
« Last Edit: April 17, 2017, 17:49:43 pm by dh42 » Logged
fourchette
« Reply #4 on: April 17, 2017, 18:05:55 pm »
you guys saved the day.
I did searched before posting but apprently not on the right keywords.
the pdf to "clean" dxf for machining, and in particular the polyline overlapping each other is rather nasty.
i copy/paste the pdf guide here for googlers =>  http://www.cambam.co.uk/forum/index.php?action=dlattach;topic=1624.0;attach=4171
And no i didn't know cambam has a gear generator but it turns out that i want to build my own gearbox for fun and precisely place them so bottom line is i prefer to stay with what i have for now
problem solved.
thanks.
« Reply #5 on: April 17, 2017, 18:12:16 pm »
Not sure, you're a French user ? (because the pseudo)
the prepare drawing exists also on the French doc
http://www.atelier-des-fougeres.fr/Cambam/Aide/tutorials/Prepare_dessins.html
« Reply #6 on: April 18, 2017, 00:12:45 am »
He followed Yogi Berra's advice:  When you come to a fork in the road, take it.
« Reply #7 on: April 18, 2017, 00:24:16 am »
Heh!  Yeah... (!!!)
L
« Reply #8 on: April 18, 2017, 04:09:10 am »
If you don't where you are going you won't know when you get there. It's like Deja Vu all over again.
Page created in 0.136 seconds with 20 queries.
