January 23, 2018, 19:36:38 pm
Pages: 1 ... 5 6 [7] 8
Author Topic: GRBL v1.1 Machine Control and GCODE sender Plugin  (Read 16436 times)
atwooddon
« Reply #90 on: April 06, 2017, 20:52:38 pm »
After several days of testing various combinations of firmware, it seems my Aurduino Mega2560 board(s) may not be compatible with GRBL.  They work fine with Marlin and basic Arduino Sketches but do not respond to any GRBL based firmware loads.  I can load Marlin and then use Gcode Sender and when opened the Marlin firmware responds with the typical response messages but with GRBL loaded no responses.  So, it appears my problem is not with CamBam or the GRBL plugin.  I used multiple versions of GRBL so my troubleshooting efforts have been fruitless so far.  Others have said the Mega2560 should work fine with GRBL/RAMPS but for me, no luck.  Arduino boards are cheap so another board may be in my future.
Thanks for everyone's help
karst.drenth
« Reply #91 on: April 06, 2017, 21:44:32 pm »
Hi Don,
There is a special Grbl version for the 2560....
Find it here: https://github.com/gnea/grbl-Mega
gerritv
« Reply #92 on: April 06, 2017, 21:45:54 pm »
It is not clear which 'grbl' image you are installing. If it is not from here, then it won't work at all: https://github.com/gnea/grbl-Mega .
Gerrit
atwooddon
« Reply #93 on: April 06, 2017, 22:09:00 pm »
gerritv
That is one that I tried along with about 3 others.
thanks
gerritv
« Reply #94 on: April 06, 2017, 22:20:51 pm »
mmnn, then I would ask questions on that GitHub. I don't have an ATMega so not much further use to you :-)
Did you try using just a terminal program such as putty? I had to add a start up delay to GrblPanel for ATmege2560 as its initialization takes longer than the other chips.
Gerrit
« Last Edit: April 06, 2017, 22:32:27 pm by gerritv » Logged
atwooddon
« Reply #95 on: April 06, 2017, 22:45:25 pm »
I tested using the basic Gcode Sender and the terminal program in Arduino INO but no change.  It seems there is no response after initial power up.  The board see data coming from the PC but never responds.  Not the board, like I said the board communicates fine using Marlin firmware.  Like I said, if I load Marlin frimware, when I use any type Gcode sender, on initial open of the board it responds with Marlin 'wake up' response.  You may be right on start up delay.  Haven't used it but will look at GRBL Panel to see if changing start up delay works.  My problem does seem to fit that symptom.
thx
« Last Edit: April 06, 2017, 23:09:51 pm by atwooddon » Logged
sraney
« Reply #96 on: April 07, 2017, 05:00:08 am »
Thank you for the information, and I'm surpised to hear yours came with GRBL v1.1, mine had an 0.9x version on it that was quite buggy.  I'll have to upgrade it to v1.1.
I was thinking of also expanding my mill, but I had concerns that lengthening might sag and cause drag on the screw.
Thank you again for the masterwork on the plugin. Now I just need stop playing around drawing squares and circles and do something real!
- SRANEY
Thnx for the compliment !  Cool
... aside from the Axis parameters and dome direction bits, it is still default as Grbl v1.1 comes out of the box.
Grtzz,
Karst
atwooddon
« Reply #97 on: April 10, 2017, 16:45:37 pm »
Quick update....  I gave up on the Arduino Mega2560 board I have.  I ordered an Arduino Uno with a GRBL shield, no sense wasting any more time trying to get the Mega to function.  The Mega works fine with Marlin but my particular board does not want to cooperate with GRBL.  Looking forward to testing with the Uno GRBL shield combo.  All the problems I have experienced trying the Mega board have nothing to do with CamBam or the GRBL Machine Control and GCODE sender.
karst.drenth
« Reply #98 on: April 10, 2017, 23:53:40 pm »
Hi All,
While setting up my 3040Z-DQ if discovered that the Z-axis resolution setting has a BUG in GRBLMachine...  Embarrassed
So shortly there will be an update Wink
Grtzz,
Karst
atwooddon
« Reply #99 on: April 12, 2017, 16:02:07 pm »
Karst
Quick update   Received the Uno/GRBL boards, loaded the GRBL hex file (version 1.1f) on the UNO and bingo everything seems to work as expected running a simple file.  Have not attached the GRBL board nor any steppers yet.
Thanks again for your efforts
MrJTJinx
« Reply #100 on: May 28, 2017, 20:04:26 pm »
Hi Guys
I'm having a problem with this GRBL Plugin
every time i open Cambam, it immediately shuts down again with this plugin in the plugin folder.
when i remove it Cambam opens OK again.
any help would be appreciated.
« Reply #101 on: May 28, 2017, 20:20:28 pm »
Sir,
You need to inform us of which version of CB you're using, and which version (if more than one) of the GRBL plugin.
« Reply #102 on: May 29, 2017, 08:21:59 am »
HI all
I had spare atmega 2560 so thought i would give the plugin a burl screen shots below.
this took a little bit of noodling as it wasn't as straight forward as i'd hoped , I did get a few warnings but you can ignore these.
MrJTJinx
« Reply #103 on: May 29, 2017, 12:02:18 pm »
Hi Lloyd,
My current set up is
Cambam version   CamBamPlus-1.0-alpha12
OS                            Windows 7 32 Bit SP1
GRBL Version          grbl_v1.1f.20170131
GRBL Plugin            GRBLMachinePlugin-V1.0.0
I have no issues with CamBam.CAD.Solids.dll being in the plugin folder but when I copy GRBLMachinePlugin.dll into the folder cambam opens momentarily then crashes.
I clicked on the debug in the hope it would give you more information
I do not actually understand any of it, i'm just a clanky
It said something like
'CamBam.exe' (CLR v4.0.30319: DefaultDomain): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_32\mscorlib\v4.0_4.0.0.0__b77a5c561934e089\mscorlib.dll'. Symbols loaded.
'CamBam.exe' (CLR v4.0.30319: DefaultDomain): Loaded 'C:\Program Files\CamBam plus 1.0\CamBam.exe'. Module was built without symbols.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Windows.Forms\v4.0_4.0.0.0__b77a5c561934e089\System.Windows.Forms.dll'. Symbols loaded.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System\v4.0_4.0.0.0__b77a5c561934e089\System.dll'. Symbols loaded.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Drawing\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll'. Symbols loaded.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Program Files\CamBam plus 1.0\CamBam.CAD.dll'. Module was built without symbols.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Program Files\CamBam plus 1.0\CamBam.Geom.dll'. Module was built without symbols.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Xml\v4.0_4.0.0.0__b77a5c561934e089\System.Xml.dll'. Symbols loaded.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Configuration\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Configuration.dll'. Symbols loaded.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Core\v4.0_4.0.0.0__b77a5c561934e089\System.Core.dll'. Symbols loaded.
A first chance exception of type 'System.IO.FileNotFoundException' occurred in mscorlib.dll
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Design\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Design.dll'. Symbols loaded.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'Microsoft.GeneratedCode'.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Program Files\CamBam plus 1.0\plugins\CADExtras.dll'. Cannot find or open the PDB file.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Program Files\CamBam plus 1.0\plugins\CamBam.CAD.Solids.dll'. Cannot find or open the PDB file.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Program Files\CamBam plus 1.0\plugins\CamBamLathe.dll'. Cannot find or open the PDB file.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Program Files\CamBam plus 1.0\plugins\CamBamPlus_Toolkit.dll'. Cannot find or open the PDB file.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Program Files\CamBam plus 1.0\plugins\CamBamPrintV3200.dll'. Cannot find or open the PDB file.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Program Files\CamBam plus 1.0\plugins\CAMToolbarAddins.dll'. Cannot find or open the PDB file.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Program Files\CamBam plus 1.0\plugins\cb2cm.dll'. Cannot find or open the PDB file.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Program Files\CamBam plus 1.0\plugins\CutViewer.dll'. Cannot find or open the PDB file.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Program Files\CamBam plus 1.0\plugins\DigitizePlugin.dll'. Cannot find or open the PDB file.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Program Files\CamBam plus 1.0\plugins\ExcellonIO.dll'. Cannot find or open the PDB file.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Program Files\CamBam plus 1.0\plugins\GRBLMachinePlugin.dll'. Cannot find or open the PDB file.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Program Files\CamBam plus 1.0\plugins\HeightMapPlugin.dll'. Module was built without symbols.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Program Files\CamBam plus 1.0\plugins\PluginManagerRegister.dll'. Cannot find or open the PDB file.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Program Files\CamBam plus 1.0\plugins\RadiusPlugin.dll'. Cannot find or open the PDB file.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Program Files\CamBam plus 1.0\plugins\Slotter.dll'. Cannot find or open the PDB file.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Program Files\CamBam plus 1.0\plugins\TapMate.dll'. Cannot find or open the PDB file.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Program Files\CamBam plus 1.0\plugins\trochomops.dll'. Cannot find or open the PDB file.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Program Files\CamBam plus 1.0\plugins\ViewToolbarAddins.dll'. Cannot find or open the PDB file.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Program Files\CamBam plus 1.0\plugins\Zoom.dll'. Cannot find or open the PDB file.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Program Files\CamBam plus 1.0\OpenTK.dll'. Cannot find or open the PDB file.
A first chance exception of type 'System.DllNotFoundException' occurred in OpenTK.dll
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Accessibility\v4.0_4.0.0.0__b03f5f7f11d50a3a\Accessibility.dll'. Symbols loaded.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_32\System.Web\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Web.dll'. Symbols loaded.
The thread 0x1450 has exited with code 259 (0x103).
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_32\System.Data\v4.0_4.0.0.0__b77a5c561934e089\System.Data.dll'. Symbols loaded.
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Drawing.Design\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Drawing.Design.dll'. Symbols loaded.
A first chance exception of type 'System.NotSupportedException' occurred in mscorlib.dll
'CamBam.exe' (CLR v4.0.30319: CamBam.exe): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Management\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Management.dll'. Symbols loaded.
A first chance exception of type 'System.Runtime.InteropServices.COMException' occurred in System.Management.dll
The thread 0x148c has exited with code 259 (0x103).
A first chance exception of type 'System.Runtime.InteropServices.COMException' occurred in CamBam.exe
An unhandled exception of type 'System.Runtime.InteropServices.COMException' occurred in CamBam.exe
Additional information: The executable program that this service is configured to run in does not implement the service. (Exception from HRESULT: 0x8007043B)
The program '[4760] CamBam.exe' has exited with code 0 (0x0).
The program '[4760] CamBam.exe: Program Trace' has exited with code 0 (0x0).
Hope this helps
Jason
« Reply #104 on: May 29, 2017, 12:08:36 pm »
HI Jason
upgrade your windows 7-32 to service pack 3 and all will be fine.
Page created in 0.205 seconds with 18 queries.
