May 25, 2018, 10:00:36 am
Pages: 1 2 [3]
Author Topic: First attempt to do 4 axis toolpaths from a 3D model  (Read 7375 times)
quoy25
carpe diem
« Reply #30 on: April 18, 2017, 19:29:26 pm »
Merci David , et chapeau bas pour cet utilitaire indispensable !
principe simple dans le concept, fallait y penser ! encore une fois bravo , je teste des que possible ...
« Last Edit: April 18, 2017, 19:33:39 pm by quoy25 » Logged
« Reply #31 on: September 12, 2017, 23:17:25 pm »
I just adds a plugin version on the website
http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/Unroll3D.html
http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/Unroll3D_FR.html
SquibLoad
« Reply #32 on: September 13, 2017, 04:55:37 am »
This is fantastic, I can't wait to try it!
Would it be possible to allow the choice of which axis to align?
Many milling machines orient a 4th axis along the X axis rather than the Y axis.
Regardless, thanks for this!
It seems that the release of CamBam 1.0 has inspired quite a burst of creativity.
Many, many excellent new plugins have arrived in the last few months, or updates and enhancements to older plugins.
Great fun!
« Reply #33 on: September 13, 2017, 08:04:13 am »
Nice one  Grin
« Reply #34 on: September 13, 2017, 16:54:22 pm »
The unroll orientation is not really linked to the 4th axis alignment, it only generate a surface ; just rotate the resulting unrolled surface by 90° before applying the 3D mop, so you are able to wrap it on another axis.
For the next release (if that works  Smiley ) I planed a 'test diameter' button that will allow to check for the min stock diameter needed to cut the shape (not always easy to find if the model have a tortuous shape) ; I also want to try to speed up calculation, that is very slow  Cry
« Reply #35 on: September 13, 2017, 18:41:31 pm »
Why not combine it with Wrapper, or at least parts of it ?
« Reply #36 on: September 13, 2017, 19:48:52 pm »
Not sure what can be combined  Huh  Wrapper act only on a Gcode and after the shape has been unrolled there is MOP creation that remain to do and job to do with boundaries to avoid that the tool down at the ends.
currently, on the wrapper side, I just set the base Z to the same value as unroll radius, and the diameter to 2x the radius.
With the integrated wrap option in the post pro, there is no way to set the wrap diameter, it is the stock surface value of each mop that is used as wrap radius.
If you want to use the PP to wrap, you must change some setting on a copy of you preferred PP.
1) in the Rotary section, set the right value for Axis of spin and Rotary axis. (in my case, Y and A)
Axis of spin define the axis of alignment of the 4th axis, Rotary axis define the letter used for the 4th axis
2) set rotary wrap to True to enable GCode wrapping
3) you must also edit the macro in the Moves and Canned Cycles sections to remove the axis that is wrapped.
In my case my 4th axis is aligned on Y, so it is the X that is wrapped.
In all macros, I remove the {$_x} macro, so for feedmove the build-in macro is {$g1} {$_f} {$_x} {$_y} {$_z} {$_a} {$_b} {$_c} and become {$g1} {$_f} {$_y} {$_z} {$_a} {$_b} {$_c}
It is not needed to set the Arc Output to convert to line, it is done automatically when Rotary wrap is used.
I attach a CB model that has been done with the following settings.
The unroll settings
The Wrapper settings
The result on NCplot
With CB V1.0, the wrapper plugin is no longer needed for this king of job where rotation is always 360° and the Wrap with the PP is really simpler to use than the plugin.
* unroll_test_full.zip (2826.19 KB - downloaded 58 times.)
« Last Edit: September 14, 2017, 01:52:55 am by dh42 » Logged
Uriel
« Reply #37 on: January 30, 2018, 14:13:46 pm »
Merci beaucoup David, super job !  Wink
I had just finalized the code that gave the same thing under blender !
But I notice (if I not mistaken) that it will ignore the fact that the milling cutter have to be smaller in width as we get closer to zero on Z axis. (For don't touche the near shapes).
I search to try to make a simple script (on CamBam) that scan only make one passage in 3D along the axis of rotation, and rotate the object of "X" degrees and repeat the operation as selected times.
And after that, keep every toolpath to make only one.
Have I been clear?
Thank you ! And have a good day  Tongue
Friendly
« Last Edit: January 30, 2018, 14:15:48 pm by Uriel » Logged
« Reply #38 on: January 31, 2018, 10:30:12 am »
The plugin dot not return toolpaths, it just scan the 3D model and unroll it, so you get the same surface, but unrolled. The tool correction is done by the 3D MOP itself when applied.
I attached a script version on this message, maybe it can be of some help.
http://www.cambam.co.uk/forum/index.php?topic=6427.msg51417#msg51417
Also, for French users, there is a small doc here
http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/Unroll3D_doc_FR.html
Uriel
« Reply #39 on: February 02, 2018, 21:09:46 pm »
Thank you David.
I know that the plugin dot not return toolpaths  Cheesy
Thank you for your sripts and documentation.
But if we will a "real" toolpath who respect the fact that the tool is more likely to touch the shapes near the bottom than at the top, we are forced to use rotation+toolpath.
A simple wrappage don't do that. (except with a good post processing who inclued this contraint, but I don't think that on this presented)
(Note : And for my CNC it is more simple, I don't need to wrap, I have wired a swich toggle who permute the Y axis to rotary axis and so, a simple XYZ toolpath work very well !)
have a good day  Roll Eyes
Pages: 1 2 [3]
Page created in 0.12 seconds with 18 queries.
