December 17, 2018, 04:33:37 am
Pages: 1 ... 6 7 [8] 9 10 ... 13
Author Topic: CamBam plus V1.0 (Linux development release)  (Read 36803 times)
« Reply #105 on: November 20, 2017, 16:04:25 pm »
Hi Andy,
I have the following problem and am not sure itis related to CB, Mono or Linux: The file open dialog lists only .dxf and .cb files despite 'all geometry files' being selected. Even if I select .step acual .step files are not listed. I have to enter '*.*' and hit Enter to make the dialog list all files in the directory.
A screenshot is attached. There are .step files there which are not listed.
newlinuxuser
« Reply #106 on: November 27, 2017, 21:42:40 pm »
CamBam 1.0 rel 14 installed on ubuntu 16.04 - 64 shows all the geometry files.
Attached a screenshot.
Saluti,
Andrea
« Reply #107 on: November 27, 2017, 22:25:36 pm »
One problem that needs to be fixed - the file open filter is case sensitive in Linux, so .DXF, .STEP extensions won't be listed where .dxf and .step will.   Sad
« Reply #108 on: June 28, 2018, 15:13:02 pm »
The latest V1.0 alpha 16 release is now available for Linux…
http://www.cambam.info/ref/ref.linux#devt
Release notes are at the bottom of the what's new page.
Changes specific to the Linux release...
. After many days trying to fix the point list editor 'add new row' bug I have compromised with an 'Add' button to
add extra points.  This control will at some point be re-written into something less windows.forms dependent.
I have also changed the number formatting to only show 'sensible' decimal points, which expands when in edit.
Similar changes are also planned for other platform releases soon.
. The system library download has only changed a little since alpha14, so you may choose to update this manually or not at all.
Two new post processors were added : RotaryX.cbpp and RotaryY.cbpp for the 4th axis wrapping functionality.
A new sample file 'solids-example.cb' was added to demonstrate some 3D scripting methods.
The Raspberry Pi release is coming as soon as I fix my raspberry pi development box.
(...maybe using it as a robot brain was not so smart!)  Roll Eyes
Andy [10bulls]
SteveT
« Reply #109 on: June 28, 2018, 16:55:21 pm »
Hi Andy, Can only see Alpha 14 of the Linux version?
Steve
« Reply #110 on: June 28, 2018, 17:02:11 pm »
Sorry Steve, I just gave the web server a thump... is that better?
SteveT
« Reply #111 on: June 28, 2018, 17:04:24 pm »
Thanks, Andy I will give it a try  Grin
Steve
SteveT
« Reply #112 on: June 28, 2018, 17:39:18 pm »
I have Alpha 16 up and running on Ubuntu 18.04lts imported tools and plugins and loaded my current project with no problems, it's only a simple part I am making but all the cutting paths and Gcode generate with no problems on the new system.
Thanks, Andy for the continuing development.
Steve
newlinuxuser
« Reply #113 on: July 04, 2018, 14:01:41 pm »
Hello Andy,
the last release alpha 16 stalls on opening files from menu open or clicking on the open file icon.
If I try to open the files from the recent list no problem.
No problem also if I open the files from the file manager (nautilus).
If I run Cambam as root everything works good, but I don't think this is a good fixing.  Undecided
Ubuntu 16,04 64
Mono JIT compiler version 5.14.0.158 (tarball Tue Jul  3 09:14:52 UTC 2018)
Thanks you for all,
Andrea
SteveT
« Reply #114 on: July 04, 2018, 14:20:43 pm »
Hello Andy,
Ubuntu 16,04 64
Thanks you for all,
Andrea
Try deleting the "CamBam1.0.config" file that can be found in the "Home/.config/CamBam plus 1.0" when you re-start CB the file is regenerated, you will need to set your preferences again in CB; but it solved a similar problem I was having.
newlinuxuser
« Reply #115 on: July 04, 2018, 16:03:26 pm »
Thanks you Steve for your help, but the problem is still here.  Angry
I deleted the config file, a new file was rigenerated but cambam still stall in the opening files.
It never crash, stays thinking, I have to kill mono by terminal.
« Reply #116 on: July 04, 2018, 18:23:54 pm »
Having been a long-time 'ix user, I have seen many situations where applications must be run as root, or at least via a super-user command, in order to gain access to the various paths necessary.
It's not really a 'defect' in the application so much as a 'need'.
If I have to 'sudo' to an app in Linux, so be it.  It only hurts to have to do that if your system has multiple users.  If you are the only user, then you ARE the super-user, and it shouldn't harm your sensibilities to use those privileges, or simply log in as root, and do it that way.
« Reply #117 on: July 04, 2018, 20:49:06 pm »
You may find useful this thread
http://www.cambam.co.uk/forum/index.php?topic=6770.0
CB hanging on file open is mentioned there.
I updated to R16 by just extracting the files in the root of the '/CamBam1.0' folder. Didn't update anything else but deleted the 'Extrude Solid' plugin since it is no longer needed. And it works OK. Same Ubuntu 16.04-64 bit
« Last Edit: July 04, 2018, 20:52:49 pm by Dragonfly » Logged
llamatrails
« Reply #118 on: July 04, 2018, 23:01:42 pm »
May also want to update the CamBam1.0-mono.system.tgz files.  The size on disk is larger than the one I had from my previous install of CamBam1.0 on Linux.
For me, on Ubuntu 18.04 LTS, the new alpha16-64bit is a lot faster on startup and seems snappier.
Very happy, Thanks for the hard work !!!
Rick
TIA,
Rick
« Reply #119 on: July 05, 2018, 00:09:02 am »
Hello Andrea,
Your mono compiler looks like a recent version, but can you please run...
dpkg --list | grep mono
If you are on Ubuntu 16.04, you should be able to get mono libraries to at least version 5.12 following the instructions
on the mono-project install page...
https://www.mono-project.com/download/stable/
Then installing mono-compete.
Sometimes  'dpkg --list | grep mono' can report a mismatch of libmono versions, which don't automatically upgrade due to dependency issues.
Are you installing CamBam into your home folder, or are you copying it to a shared area?
Thank you for your feedback!
Page created in 0.151 seconds with 20 queries.
