July 22, 2019, 23:33:15 pm
Author Topic: Warning messages with Plugins and CamBam v1.0  (Read 7542 times)
« on: December 23, 2016, 10:39:41 am »
Note: You may require, Tool->Options->Diagnostic Level = 4 in order to see these errors
I've not tried other settings because I always have mine set to 4.
If you get warning messages like the ones in the attached picture, this can fix it.
The first thing I have to say is, these errors are to do with security of your computer so if you use the following information that is YOUR choice.
1. move the dll file of any affected plugin to a folder where file privileges are granted.
I tried this on my sytem with the dll still in CamBam's Plugins folder and it would not work, I moved the file to another drive first.
2. right click the dll file and select Properites
3. on the General tab, you will see at the bottom a button called 'Unblock', click that then 'Apply', then 'OK'
The file should now load okay.
« Last Edit: December 23, 2016, 15:39:16 pm by EddyCurrent » Logged
michel
« Reply #1 on: December 23, 2016, 14:52:48 pm »
Hi Eddy
thanks . It is working now . I only have a few logs left. What is this ?
« Reply #2 on: December 23, 2016, 14:55:00 pm »
Those should not be in the plugins folder, only in the main CamBam folder, you should move or delete them
michel
« Reply #3 on: December 23, 2016, 20:54:58 pm »
Hi Eddy
i copied those from the folder of my 0.9.8 version . Should i delete them there too ? What function do they have ?
michel
« Reply #4 on: December 23, 2016, 20:58:06 pm »
Michel,
0.9.8 and 1.0 run independently.  DO NOT destroy ANYTHING in your 9.8 directories.
You should read the entirety of 10bulls's descriptions in the announcements.
michel
« Reply #5 on: December 23, 2016, 21:06:05 pm »
Hi Lloyd
i do not touch the 0.9.8  ( to precious for me)  Wink
I removed the files in version 1.0 and now i get no error messages any longer.
I runned several gcodes and it seems to work fine for me.
michel
« Reply #6 on: December 23, 2016, 21:09:32 pm »
"...i copied those from the folder of my 0.9.8 version . Should i delete them there too ?"
Michel,
I understood the statement and question above to mean "delete them from 9.8".  I imagine it's a "language difficulty" (as we've had often!  Cheesy)
« Reply #7 on: December 23, 2016, 23:21:11 pm »
The pb is the same with 1.0 when updating than with 0.9.8 ; sometimes ironpython.dll and some other dll are not updated when CB is installed so you get an error message because the dll are not of the right version ; to solve that, delete all but the 2 folder and the license file in the cambam install folder (for the 1.0 off course), then reinstall (repair) cambam.
http://www.cambam.co.uk/forum/index.php?topic=5121.msg40528#msg40528
all the dll on your image must not be in the plugin folder ; they are not plugins Wink
« Last Edit: December 23, 2016, 23:22:45 pm by dh42 » Logged
joebmh
« Reply #8 on: January 25, 2017, 17:12:35 pm »
Thank you Eddie! I would've saved myself a couple hours if I had read this post first. I think it would be good to put this notice next to the download link for ver1.0
Joe
jorgemarmo
« Reply #9 on: March 18, 2017, 14:22:33 pm »
Hi David!
thank you! That indeed "solved" my problem for the 1.0 version but not completely... I finally find the problem and I'll share it here, it might be useful for someone else.
After changing the "permissions" on the 1.0 plugin folder, the errors on the console went away, but still I wasn't able to see NumericalMove window... and the 0.98 dll file wasn't "blocked".
My problem was a second screen! it is a laptop with an external screen and even tough the second screen was disabled (not just turned off), the NumericalMove windows was being created on the disabled screen, most likely were I used it for the last time. So basically I solved my problem on the 0.98 by enabling the laptop screen, dragging the NumMove to the the external screen  and disabling again the laptop screen.
Sorry for the dummy problem. And thank you all for your help!
« Reply #10 on: March 18, 2017, 14:43:30 pm »
Trick about resetting the saved data for numove or others plugins
http://www.cambam.co.uk/forum/index.php?topic=2815.msg51877#msg51877
Page created in 0.147 seconds with 19 queries.
