February 19, 2019, 04:17:41 am
Pages: 1 ... 11 12 [13] 14 15
Author Topic: CamBam plus V1.0 (new development release)  (Read 66760 times)
EL34
« Reply #180 on: March 02, 2018, 16:43:18 pm »
yeah, was just doing that
The windows 7 forums may have some info
Mach 3, Cambam, Autodesk Quickcad 8, machine info -> http://www.el34world.com/Misc/Cnc/CNC0.htm
EL34
« Reply #181 on: March 02, 2018, 16:53:10 pm »
Akkk, should have started there first
Was pretty simple
The registry was messed up
It was still pointing to the 0.9.8 program which no longer exist on this machine
I edited the registry key to point to 1.0
Then I was able to associate a .cb file with cambam 1.0
Here's the registry path in case anyone else runs into this situation
« Reply #182 on: March 02, 2018, 17:03:04 pm »
Very good.
It's a coincidence you should come back on the forum today, I've been playing about with valves myself today trying to get the Leslie West tone. He used SUNN amps years ago with KT88 valves.
« Last Edit: March 02, 2018, 19:04:21 pm by EddyCurrent » Logged
EL34
« Reply #183 on: March 02, 2018, 17:04:10 pm »
Good luck with that
Leslie's hands were a big part of his tone Smiley
jim_s
« Reply #184 on: April 17, 2018, 15:54:46 pm »
Nice!! Been a while since I've used CamBam, but have a new project to do, and just checked on the off chance there might have been an update from the venerable 0.9.8N, and found there's a 1.0 - Super Duper Cool! (and its available for Linux, too - Super Duperer Cooler!!)
As a long-time user and license holder, I genuinely appreciate all of your work on CamBam - it has brought much joy, success and (emotional :-) richness to my CNC work.
jim1108
« Reply #185 on: May 26, 2018, 19:57:50 pm »
Hello everyone.
Here is something I stumbled across when comparing version .98 to version 1.0.
Same cb file (attached below)  but posted (fanuc) with version 1.0 then opened in .98, and posted again without any changes for comparison of code.
Both post correctly, but the 1.0 nc file measures 101K and the .98 file measures only 61k. They both seem to go about the pocket milling slightly diffrently when looking at the code. My machine only has 256k of memory.
The 1.0 post actually takes 2 minutes longer according to NC Corrector simulator.
So, its a larger file with 1.0 that takes longer to sum it up.
This is a significant difference in file size. I tried it on another cb job file that involved alot of slope cutting and the sizes were the same.
The only difference with the cb file in question is that this file has pocket milling, and that is where it adds more code.
Has anyone run across this, and is it only when pocket milling is used?
* C006651626OP1.cb (23.2 KB - downloaded 39 times.)
* Fanuc.cbpp (1.95 KB - downloaded 37 times.)
« Reply #186 on: May 27, 2018, 00:02:12 am »
hello
cambam V1 outputs the correct code. It seems like you found an unknown bug in Cambam 0.9.8.
In the Pocket mop you use a spiral lead in with a 10 deg. spiral angle.
It looks like V 0.9.8 ignores this spiral lead in and just goes straight down to Z -0.1875.
This saves Cambam 0.9.8 the entire spiral tool path with every depth increment.
What needs to be investigated in more detail.
« Last Edit: May 27, 2018, 00:05:49 am by pixelmaker » Logged
jim1108
« Reply #187 on: May 27, 2018, 13:50:03 pm »
Yes, I did notice the plunge move in .98.
I just assumed there was not enough room for a 10 degree spiral, so it just plunged instead.
Another cam package that I use (SheetCam) will plunge instead of ramping if there is not enough room so I assumed it was normal.
Edit: I switched optimization mode from 0.9.7 to 0.9.8 and it spiraled down correctly instead of plunging.
« Last Edit: May 27, 2018, 13:57:48 pm by jim1108 » Logged
« Reply #188 on: June 24, 2018, 00:24:43 am »
Due to post Brexit calendar austerity measures, coupled with US trade sanctions on working hours, what at first glance appears to be several months since the previous development release actual only equates to a few short, EU approved weeks!  Roll Eyes
That said, I am pleased to announce a new (official) V1.0 alpha 15 release…
http://www.cambam.info/downloads/#devt
As always, release notes are at the bottom of the what's new page.
The main focus has still been trying to make sure V1.0 is a big improvement over venerable 0.9.8 and not to introduce any new or unexpected problems.
If you have already made the move to V1.0, there is a new menu option, 'Tools - set file associations', which will associate .cb files with the current running CamBam version.
I think we are getting near now to retiring 0.9.8 but please shout out if anything looks odd or unexpected in V1.0.
I very much appreciate the amount of trust placed in CamBam's g-code, with your expensive and passionately built
CNC machinery and tools, so thank you very much for your patience and feedback while we make sure everything works as expected.
Andy [10bulls]
« Last Edit: June 24, 2018, 00:28:21 am by 10bulls » Logged
« Reply #189 on: June 24, 2018, 00:36:55 am »
Neat, Andy, and thank you!  I shall try it again!
SteveT
« Reply #190 on: June 24, 2018, 09:46:42 am »
Great news Andy, cannot wait for the Linux version Brexit permitting  Cheesy
« Reply #191 on: June 24, 2018, 12:17:40 pm »
Thank you, Andy.
« Reply #192 on: June 24, 2018, 13:50:07 pm »
You are all very welcome!
Linux release will be next week.
« Reply #193 on: June 24, 2018, 16:52:45 pm »
Thanks for the development work!
I got a crash however, trying to set file associations. Could it be because I still keep 0.9.8  and didn't completely remove R14?
« Reply #194 on: June 24, 2018, 18:41:16 pm »
I did the same, R15 installed over R14, 0.98 still here, and file association works (W7 - 64, admin session) ...
« Last Edit: June 24, 2018, 18:43:41 pm by dh42 » Logged
Page created in 0.182 seconds with 20 queries.
