February 16, 2019, 22:20:25 pm
Pages: 1 ... 9 10 [11] 12 13 ... 15
Author Topic: CamBam plus V1.0 (new development release)  (Read 66592 times)
« Reply #150 on: September 19, 2017, 12:48:16 pm »
First what I see while trying to install is.
I can´t change the folder, the browse button is grey
And the change of the volume also don´t work
No asking for admin or user rights while installing
« Last Edit: September 19, 2017, 12:55:40 pm by pixelmaker » Logged
« Reply #151 on: September 19, 2017, 15:52:03 pm »
Andy say me that there is almost no change in the R 13_4 except a new installer based on net framework4 that maybe will solve installation problems on W10. The 'set permission' form as been removed, so I assume the permissions are set automatically.
« Reply #152 on: September 19, 2017, 16:01:31 pm »
Please Andy, we see that you visit this forum (last visit 19 September 2017, 12:38:43), perhaps you can write same words to the new version.
I think you do a mismatch with 'local time' Wink ; the last Andy's visit is the 06 September 2017, 10:19:18 (to kill spam I think)
tau
« Reply #153 on: September 19, 2017, 19:25:32 pm »
Hmm, unfortunately 3D Mouse plugin throws "Error loading plugin" ... Roll Eyes
and as Ralf stated: Greyed out installation folder (so it is being installed in default path C:\Program Files (x86)...!
Tunc
« Reply #154 on: September 19, 2017, 20:59:58 pm »
Tunc
The plugin works fine for me.
« Reply #155 on: September 19, 2017, 21:28:24 pm »
Do we know if the precision error for inch users has been fixed when generating 3D tool paths?
« Reply #156 on: September 19, 2017, 21:32:37 pm »
No, not yet, it is being investigated currently by Andy.
« Reply #157 on: September 19, 2017, 21:34:30 pm »
Darn.  I so want to upgrade to 1.0 because it seems to execute better under W10 than 0.98.
« Reply #158 on: September 19, 2017, 21:37:55 pm »
I think this problem with 3D is on the top of the todo list, so we can hope for solution in a short time .
tau
« Reply #159 on: September 20, 2017, 09:29:17 am »
Tunc
I'll give it another try tonight (even though i tried it multiple times yesterday with same results), but my assumption would be it could have something to do with the UAC rights on the folders in this path (C:\Program Files (x86)\...)?!
But again, i think your 3D Mouse.dll doesn't need to have any elevated rights other than reading from it.
++++++++ Update +++++++++
Tried from originally installed path and i've copied the whole "CamBam plus 1.0" folder to other Drive E:\ with same results. Using 3D Mouse Driver plugin v10.4.10.
Same Mouse driver using with CB 0.98 on drive E: works flawless!
Regards, Tunc
« Last Edit: September 20, 2017, 15:46:07 pm by tau » Logged
StefanR.
« Reply #160 on: September 21, 2017, 21:18:53 pm »
I have a problem with the plugins for V1.0 as they wont be loaded.
For example
  • Slotter.dll
  • ArcText.dll
  • trochomops.dll
  • aligner.dll
  • corner.dll
  • MeasureXYZ.dll
For all plugins the following error is given:
Error loading plugin C:\...\plugin.dll
An attempt was made to load an assembly from a network location which would have caused the assembly to be sandboxed in previous versions of the .Net framework. This release of the .NET framework does not enable CAS policy by default, so this load is dangerous. If this load is not intended to sandbox the assembly, pleas enable load from loadFromRemoteSources switch. See http:/go.micro(then end of screen and can't see the rest).
I tried a clean install, the initial alpha 12 version, alpha version 13.3 and allpha version 13.4.
Any ideas?
« Reply #161 on: September 21, 2017, 21:26:09 pm »
Read this;
http://www.cambam.co.uk/forum/index.php?topic=6294.msg50090#msg50090
StefanR.
« Reply #162 on: September 21, 2017, 21:32:54 pm »
Thanks Eddy!
Solved all problems Smiley
« Reply #163 on: November 17, 2017, 08:45:29 am »
Why is there never a change log at each test release ?
« Last Edit: November 17, 2017, 14:38:53 pm by EddyCurrent » Logged
« Reply #164 on: November 17, 2017, 23:41:01 pm »
in 14_2
- a bug has been solved with the max crossover distance that sometime is ignored in pockets, so the tool forgot to move to clearance plane (and the display of the rapids on the screen was also bad)
What I know about the last 14_3 release
- The Browse button to choose install path is back again in the installer
- Display problem with very small 3D object has been solved (*)
- this bug has been solved
http://www.cambam.co.uk/forum/index.php?topic=6776.0
* very small 3D objects (from the point of view of the numerical values) gives some glitches on the display
example with the part on the picture 1 that is 0.8 x 0.8 x 0.09 units and that have glitches ; the same part sized to 106 x 106 x 11 units is displaying OK (picture 2)
Andy say me that He planed to add STL export and SVG import/export function soon
Page created in 0.153 seconds with 20 queries.
