February 23, 2018, 05:45:53 am
Pages: 1 ... 7 8 [9] 10 11 12
Author Topic: CamBam plus V1.0 (new development release)  (Read 36847 times)
« Reply #120 on: March 17, 2017, 18:12:33 pm »
version provided with CB when installing is 1.5, version from jeff birt is 1.5.1 and only this version handle .drd
... and I just see that there is a typo error in the name in the list: ecellon insteed excellon   Grin
« Last Edit: March 17, 2017, 19:43:38 pm by dh42 » Logged
« Reply #121 on: March 17, 2017, 18:25:41 pm »
About 3D - Bob and David - I think a discussion between the users on possible improvement is worth a separate thread. If you open one I'll join with my own impressions and ideas.
« Last Edit: March 17, 2017, 19:43:46 pm by dh42 » Logged
Jeff_Birt
« Reply #122 on: March 17, 2017, 19:21:12 pm »
I'll fix the typo. I did recompile the plug-in for V1.0, I'll go back and fix the typo and then upload.
« Last Edit: March 17, 2017, 19:43:53 pm by dh42 » Logged
« Reply #123 on: March 17, 2017, 19:36:05 pm »
Thanks jeff Wink
Discussion about 3D calculation continue as a new topic here
http://www.cambam.co.uk/forum/index.php?topic=6488.0
GeoffreyGRoy
« Reply #124 on: March 19, 2017, 05:08:42 am »
I have bee trying out the STEP file import in R13.  For a largish file (8 Mb), the load either fails or goes on for a very long time.  Converting the file to STL (using another app), the model loads in seconds.  The STEP file is included in the attachment.
Geoff
* decorative_sun_3d_model_step.zip (1963.38 KB - downloaded 69 times.)
« Reply #125 on: March 19, 2017, 11:34:23 am »
hello
if I open your file I get after app. 2 minutes a warning and for every curve an expected surface curve.
Parsing file...
Extracting objects...
Unhandled style usage CURVE_STYLE
ID:#26 expected Curve found SURFACE_CURVE
ID:#997 expected Curve found SURFACE_CURVE
ID:#1547 expected Curve found SURFACE_CURVE
ID:#1975 expected Curve found SURFACE_CURVE
ID:#2236 expected Curve found SURFACE_CURVE
ID:#2504 expected Curve found SURFACE_CURVE
ID:#3362 expected Curve found SURFACE_CURVE
ID:#3587 expected Curve found SURFACE_CURVE
ID:#3655 expected Curve found SURFACE_CURVE
ID:#3828 expected Curve found SURFACE_CURVE
ID:#3857 expected Curve found SURFACE_CURVE
ID:#3882 expected Curve found SURFACE_CURVE
ID:#4364 expected Curve found SURFACE_CURVE
ID:#4744 expected Curve found SURFACE_CURVE
ID:#5107 expected Curve found SURFACE_CURVE
ID:#5290 expected Curve found SURFACE_CURVE
ID:#5658 expected Curve found SURFACE_CURVE
ID:#6112 expected Curve found SURF
Cambam opens the file after some minutes and the surface is converted into very tiny triangles.
If cambam cant work with the curved surface in step files it will be better to convert the object outside in a mesh object.
« Reply #126 on: March 19, 2017, 11:41:04 am »
Bspline surfaces are not totally finished in this version some works but are not cut, and other do not works ; be patient  Wink
« Reply #127 on: March 31, 2017, 14:39:59 pm »
I have 0.9.8 and 1.0.12 installed side by side. And it seems they share the recently opened file list. I was trying 1.0 with some .STEP files, the closed it and opened 0.9.8. And the .STEP files names were in the list of recently opened.
GeoffreyGRoy
« Reply #128 on: April 30, 2017, 09:35:44 am »
I like CamBam a lot, but the one slight annoyance is the time it takes to startup.  Many applications use s splash screen to mask the delay. So, any chance of a nice CamBam splash screen in V1?
Geoff
newlinuxuser
« Reply #129 on: April 30, 2017, 21:06:40 pm »
I use only linux version, cambam take about 5 seconds to start for the first time and about 2 seconds the next times.
Only 3 GB ram and an old 2 duo Intel T9400.
Maybe there is something wrong about your windows installation?
django013
« Reply #130 on: May 03, 2017, 07:57:37 am »
Same here: cambam on linux/mono with an old amd cpu but ssd - 1s to start
So from my point of view: splashscreen is the wrong place to waste menpower Wink
« Reply #131 on: May 03, 2017, 17:46:03 pm »
On Win XP 32 bit
CB 0.98 > 8s to start
CB 1.0 > 5s to start
on the same PC it seems that it start faster on Win 7 - 64 bits (not 'measured')
« Reply #132 on: May 03, 2017, 21:04:22 pm »
Starting the first time after a reboot is probably somewhat slower if windoz has to also load all the DLLs for plugins.  Afterwards it's not needed so should be fast.
My personal wish list at the moment would include being able to perform the same transform/align ops on the stock rectangle vs. needing to specify offsets, plus the ability to define round stock easily for passing on to CutViewer.
Arie kabaalstra
why buy one, if you can build one?
« Reply #133 on: June 01, 2017, 15:27:25 pm »
Yes, not yet "officially" version on the forum, but you can DL it on the ftp
Do you have a link?.. i'd like to be able to work with Step files as well
« Reply #134 on: June 01, 2017, 20:53:46 pm »
Have you tried this script ?
http://www.cambam.co.uk/forum/index.php?topic=3553.msg24654#msg24654
http://www.cambam.co.uk/downloads/dw/CamBamPlus-1.0-alpha13_3.msi
you must install 1.0 R12 prior to install the R13_3
note that not all surfaces are working for STEP import ; Bspline surfaces are not finished.
Page created in 0.15 seconds with 20 queries.
