January 22, 2020, 14:22:16 pm
Pages: 1 [2]
Author Topic: STOP writing plugins!!!  (Read 11610 times)
« Reply #15 on: November 29, 2016, 17:38:20 pm »
you can ave Arc2F in a polyline, but apparently you can't create them (or at least i couldn't find a manner to to so).
To create an arc in a polyline, if you works with point, just add a "bulge" value for the first point of the arc ;
in the polylineitem, there is a bulge variable.
  public double Bulge;
if you works with segments then you can directly add an arc2F, a line2F or a line3F to a polyline
  public void Add(Arc2F arc, double tolerance);
    public void Add(Line2F line, double tolerance);
    public void Add(Line3F line, double tolerance);
I don't know how to convert an arc to a bulge value with math, but in the arc2F, there is a readonly bulge value.
public double Bulge { get; }
so I think we have all what is needed to draw what we want.
http://www.atelier-des-fougeres.fr/Cambam/Aide/API%20Doc/Cambam_cad_dll/Cambam_cad/Polyline/Polyline_point_property.png
« Reply #16 on: November 29, 2016, 21:04:28 pm »
A bit offtopic, but the bulge is just tan (arc sweep / 4),
Arc segment may be inserted in polyline via Add(Point3F, bulge)
I think geometry structures (PointxF, LinexF, ArcxF etc) and Polyline API are stable enough and unlikely to be changed. Higher-level APIs is the other matter of course.
I do all CAD work in other software, so in CB my CAD-work is a small adjustments to account for the machining strategy, then comes the CAM :-) I think CAD-mode of CB (+ a number of plugins) is perfectly adequate for such workflow.
« Reply #17 on: November 30, 2016, 10:18:00 am »
But in Linux there is no Arc2F Object,
ap1 = new Point3F (start.X, start.Y, 0);
ap2 = new Point3F (end.X, end.Y, 0);
poly1.Add (ap1, s_bulge);
poly1.Add (ap2, s_bulge);
This code works, to add an arc, or better a "bulged" segment, otherwise the only Arc is the Arc entity.
From now I'm quite happy with CamBam API, but  some it has soem quirks, probably due to Mono, but if .NET is a "standard" not all the MS .NET parts are implemented in Mono due to Licensing problems, so we have to struggle with these problems.
« Last Edit: December 01, 2016, 07:20:47 am by onekk » Logged
« Reply #18 on: November 30, 2016, 18:46:22 pm »
You are sure ? .. strange  Huh
Arc is in CamBam.CAD.dll, but Arc2F is in CamBam.Geom.dll (and also Circle2F, line2F .. etc )
« Reply #19 on: December 01, 2016, 07:24:45 am »
I've to be blind, now I could find it.
Generally I search the object by name or by clicking on the istance of the IDE and it goes to te definition (although is only a mere list of properties name and composition) like this
namespace CamBam.Geom
[Serializable]
public struct Arc2F : IBSPItem
// Fields
public Point2F Center;
public Point2F P1;
public Point2F P2;
public RotationDirection Direction;
// Static Properties
public static Arc2F Undefined {
get;
// Properties
get;
public Point2F Midpoint {
get;
public double Radius {
get;
public double Start {
get;
public double Sweep {
get;
// Constructors
public Arc2F (Point2F center, double radius, double start, double sweep);
public Arc2F (Point2F center, Point2F p1, Point2F p2, RotationDirection dir);
public Arc2F (Point2F p1, Point2F p2, double sweep);
// Static Methods
public static double _CalcPolyArcSweep (Point2F p1, Point2F p2, Point2F pmid);
public static Arc2F GetArcFromMidpoint (Point2F p1, Point2F p2, Point2F pmid);
// Methods
public bool AngleWithinArc (double angle, double tolerance);
public Line2F ArcIntersect (Arc2F arc);
public Line2F ArcIntersect (Arc2F arc, double tolerance);
public Line2F CircleIntersect (Circle2F circle);
public Line2F CircleIntersect (Circle2F circle, double tolerance);
public double DistanceToPoint (Point2F p);
public ArcBulgeDirection GetBulgeDirectionLeftRight ();
public ArcBulgeDirection GetBulgeDirectionUpDown ();
public void GetExtrema (ref Point2F min, ref Point2F max);
public double GetPerimeter ();
public void Invert ();
public bool IsInside (Rect2F rect);
public Line2F LineIntersect (Line2F line, double tolerance);
public Point2F NearestPoint (Line2F line, ref double distance, double tolerance);
public Point2F NearestPoint (Arc2F arc, ref double distance, double tolerance);
public Point2F NearestPoint (Point2F p, ref double distance);
public Vector2F P1Tangent ();
public Vector2F P2Tangent ();
public bool RadiusOffset (double delta);
public Line2F RayIntersect (Line2F line, double tolerance);
public bool RegionInside (Rect2F rect);
public Point3FArray RenderToPoints (double tolerance);
public Arc2F[] SplitAtPoint (Point2F p);
public double SweepDiff (Point2F p);
public bool VectorInsideArc (Vector2F v);
Sorry for the inconveninence.
Pages: 1 [2]
Page created in 0.097 seconds with 19 queries.
