May 21, 2018, 19:24:34 pm
Pages: 1 ... 9 10 [11] 12 13 14
Author Topic: Trochoidal Pocket & Profile MOPs plugin (HSM)  (Read 34987 times)
dah79
« Reply #150 on: July 26, 2017, 23:29:13 pm »
Machining a pocket in 6061 AL .25"deep.  Using the Trochoidal pocket MOP, and if I change the spiral feedrate slower than cut feedrate, it follows the spiral feedrate for the whole toolpath.  I just want to slow down the initial spiral to depth cut plunge rate.
For a temporary fix, I just created a circle and used a standard pocket MOP down to -.25".  And then ran the trochoidal pocket MOP with a start point at the previous circle center.  While this works, I thought the troch MOP would handle the initial plunge....
« Reply #151 on: July 27, 2017, 00:34:20 am »
A few options:
1) Lead Move Type: Spiral, Spiral Angle: 0, Lead Move Feedrate: desired feedrate
this will follow the full spiral backward, gradually going into the depth. First rev will be hard on a cutter (slotting)
next revs will be easier since a lot of material is removed.
2) Same but Spiral Angle: 1..5 degrees.
This will use the only a part of spiral for plunging, faster time but more cutter load.
3) Lead Move Type: Tangent, Spiral Angle: 1..5 degree, Tangent Radius: ~ tool diameter / 4
This will do the helical drill you probably want. But please verify the result with the 'show cut widths' enabled, in some cases it may be placed wrong and interfere with the pocket walls )
dah79
« Reply #152 on: July 27, 2017, 13:01:46 pm »
I will try suggestion #3 and see if it works for me.  Another thing I noticed is that it doesn't get completely into the corners.  Is this possibly a setting I am missing?  Sorry for all the questions, but I had kind of gotten away from CamBam, but using this MOP is the best way for me to mill aluminum.
« Reply #153 on: July 27, 2017, 13:10:44 pm »
It's generally best to finish with a profile cut to clean things up so that would remove any left overs at the edges.
dah79
« Reply #154 on: July 27, 2017, 13:16:35 pm »
Which is what I was doing, just wondered why it didn't get closer as the bit will fit in that area.
« Reply #155 on: July 27, 2017, 13:20:14 pm »
As I see it, the plugin's power is in bulk material removal for roughing. Therefore some finishing should be added too.
dah79
« Reply #156 on: July 27, 2017, 13:23:19 pm »
I agree.  The plugin works very well for what I want/need!!  Just trying to make sure that I am not missing something obvious.
« Reply #157 on: July 27, 2017, 13:50:03 pm »
There must be a little extra space between the tool and narrow channel to consider it millable.
Otherwise the trocho slices will transform into the straight slotting (180 degrees tool engagement angle) and a possibly broken tool. This extra space is about the 5% of the tool diameter.
If the corner is wide enough but not milled completely, try changing the Minimum Stepover. Say, 0.8 instead of default 0.9.
dah79
« Reply #158 on: July 27, 2017, 14:06:50 pm »
Thank you for all the help.
This solution worked for me.
« Reply #159 on: August 15, 2017, 12:40:13 pm »
Yesterday I used the profile for the first time, and because I wanted to mill away all the stock around it I made the cut width large enough to do so.  However, I found that in doing so I was cutting air a lot of the time.  In retrospect, I realized that had I created a rectangle around the stock, the pocket version would have done the same thing with very little air cuts.
Experimenting, it seems that a rectangle large than the stock by the tool diameter in both dimensions was needed.
Thought I'd share.
« Reply #160 on: August 17, 2017, 16:07:44 pm »
Generally I got better results with the pocket version of this plugin.  Sometimes I create custom shapes with a starting tab outside the stock.  Other times I create custom pocket and island setups.  I've found to really get the most out of this you have to spend a little more time thinking about the actual machining.
« Reply #161 on: November 24, 2017, 21:39:13 pm »
I tried the profile version again on some Mic6 aluminum, 1/2" thick.  Went .4" deep with .2" DOC and 1/2" cut width and .05 roughing clearance.  I didn't used mixed cutting this time and was surprised to see how good the finish was.
I think this is a good option when cutting a fairly deep slot in aluminum and there is plenty of room for chip clearing (I just have air blast, no coolant).  Of course it's a lot slower than a straight profile.
I've pretty much settled on using the pocket op on all my parts where a toolpath can be generated.
« Reply #162 on: November 26, 2017, 18:01:12 pm »
I think this looks like a part that would be best made with thicker than desired stock.  Remove all the stock on top that is not the part.  Then flip the part into custom machined soft jaws to remove the extra thickness.  It may not be fastest for one part, but for more than one I assure you it will be much faster.  Probably face milled off the bulk of the bottom, then flycut to thickness for finish.
With this approach you could also use smaller (X/Y) stock which would save as much (or more) material as you would waste when machining off the bottom.  Joe Pi also has a great video on this on YouTube.
« Last Edit: November 26, 2017, 18:03:36 pm by Bob La Londe » Logged
« Reply #163 on: November 26, 2017, 22:59:41 pm »
No argument there, but part is one-off, and I didn't have any thicker stock.  This project is a mechanical sculpture where most parts are one-off and have few if any straight sides.  About 150 parts.  The prototype is made from plywood so everything is a flat outer profile.
A few of these parts have 1/4" through holes that can be used to screw down to a fixture plate.
« Reply #164 on: December 04, 2017, 19:26:04 pm »
Hi.
Occasionally some pocket shapes failing to produce a good Voronoi partitioning -
slicing is going fine and then just stop for no reason, often steering towards the wall.
I'm thinking about swapping the underlying Voronoi routine to the more robust one from the triangle.net project.
If you stumbled upon some really bad partial slicing, feel free to post cb files (or PM me).
I need examples of bad partitioning for testing new code.
Example of such slicing below:
« Last Edit: December 04, 2017, 19:29:49 pm by jk » Logged
Page created in 0.25 seconds with 18 queries.
