January 23, 2018, 19:38:35 pm
Pages: 1 ... 8 9 [10] 11 12 ... 14
Author Topic: Trochoidal Pocket & Profile MOPs plugin (HSM)  (Read 26382 times)
« Reply #135 on: March 29, 2017, 20:54:56 pm »
I did some specific tests and was not able to get it to duplicate.  I did have it happen more than once the other day, so I expected it to be easily replicated.  My issue may not have come from your MOP plug-in.  It might be related to the instability CamBam sometimes exhibits when its been open doing complex work for several hours.
« Reply #136 on: March 30, 2017, 10:06:22 am »
Updated first post with the version 2.1.1
* fix for the extra wide-angle slices collapsing in some cases
note: this version is a fix to 2.1.0 and do not includes Clear Inner Pockets experimental feature.
« Reply #137 on: April 01, 2017, 17:37:34 pm »
Not tried with the very last version, but with the 2.1 it has a different comportment with the start point on a circular pocket, depending on the shape position (start point set to the center)
have a look here.
http://www.cambam.co.uk/forum/index.php?topic=6514.msg52323#msg52323
« Reply #138 on: April 02, 2017, 12:19:48 pm »
dh42, thank you for bug report.
Funny enough, the circular pocket is the worst shape possible for the calculation.
Infinite number of axes of symmetry, shape skeleton is just a single center point.
Last version should bug too.
I'll see if it could be fixed .. maybe as a some 'special case' in code.
« Reply #139 on: April 05, 2017, 13:23:45 pm »
First post updated with v2.1.2
* a lot of fixes for wide-angle slices - completely missed slices, wrong entry TEA calculation etc
* special handling for circular pockets
* each slice is made from two arcs now
« Reply #140 on: April 13, 2017, 23:03:11 pm »
I started using the plugin on foamed PVC - just to get the grip on trochopocket parameters. And I like it more with each try. I even tried it on aluminum. Very conservative settings because of the low power spindle, didn't gain in time but the long fluffy chips made my router look like a real machine Smiley
« Reply #141 on: April 14, 2017, 17:03:51 pm »
I think its a great rough operation.  Biggest thing for me is I don't have to consider the extreme spike in spindle load in the corners like with a regular operation.  That allows me to use faster feeds.  It can save time on some types of operations, but with my not so rigid high speed machines it does leave some unpleasant tool marks compared to other ways of doing a job.  Hence why I primarily use it as a roughing operation.  In fact its used as standard operations in a couple of my templates.
« Reply #142 on: April 14, 2017, 19:54:58 pm »
I also regard it as an operation for removing bulk material.  I had to mill large digit shaped pockets in PVC and decided to give it a try, almost no risk for the tool and the material is not expensive Smiley  Because of that I used mixed milling mode and the bottom marks were quite acceptable.  They will be hidden anyway.
dah79
« Reply #143 on: April 19, 2017, 21:48:26 pm »
Very cool.  Where is the link to the latest version?  Thanks
« Reply #144 on: April 19, 2017, 22:10:37 pm »
http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/TrochoPocket.html
david
dah79
« Reply #145 on: April 19, 2017, 22:24:17 pm »
Thanks!
Why does my link to 'plugins' not have near as many options?
http://www.cambam.info/ref/plugin
« Last Edit: April 19, 2017, 22:29:05 pm by dah79 » Logged
« Reply #146 on: April 19, 2017, 22:32:11 pm »
it's not the same website Wink
the link you show is for "regular" plugins (done by the programmer of Cambam)
« Reply #147 on: May 06, 2017, 23:34:10 pm »
A video feedback from a French user of the plugin Wink
https://www.youtube.com/watch?v=fdo5hAbBMyw
if you want see more about the machine
http://www.usinages.com/threads/petite-fraiseuse-sur-base-de-recuperation.54721/
dah79
« Reply #148 on: July 26, 2017, 22:25:14 pm »
How do you get a circular entrance into the pocket instead of a plunge move?  I love this MOP, other than this issue.  Hopefully I am doing something wrong.
Thanks!
« Reply #149 on: July 26, 2017, 23:15:59 pm »
Lead-in, select Spiral or Tangent. Without seeing what you want to cut, I think you be better of with spiral entry
My 2
Page created in 0.206 seconds with 18 queries.
