June 16, 2019, 21:58:19 pm
Pages: 1 2 [3] 4
Author Topic: Substitute Primitive  (Read 10570 times)
« Reply #30 on: October 24, 2016, 18:33:54 pm »
I played about with undo for ages without success, I thought you could just do the opposite of the previous 'replace' operation  Grin
Not if things go sideways and you aren't sure what happened.
« Reply #31 on: November 04, 2016, 01:04:02 am »
I need to check things tomorrow.  I noticed today substitute polyline was still in the plugin menu.
« Reply #32 on: November 04, 2016, 07:54:14 am »
It might be the first version still in your plugins folder, the latest one should be in the Machining menu only.
« Reply #33 on: November 04, 2016, 10:17:12 am »
As Eddy said,named.. Entity Replace. Wink
« Reply #34 on: November 10, 2016, 22:32:23 pm »
I just did a job that got optimum use of this Plug-In today.  Actually two of them.  Multiple cavity casting molds.  Just two quick and dirty entity replace operations, tweaked position of a couple things and...  BAM.  Done.
I've got both jobs on machines right now.
« Reply #35 on: November 18, 2016, 01:20:45 am »
I just have to say... I really get a lot of use out of this plug-in.  It makes changes and adjustments so much easier and faster.
« Reply #36 on: November 18, 2016, 07:18:56 am »
That's because it was your idea Bob, and a good one at that.
« Reply #37 on: November 18, 2016, 15:51:10 pm »
The execution of it is great, and it seems like I use it every day.  I modified three molds yesterday using this plug-in.  One of them was updated three times.  It used to be that sometimes when a customer asked for a redesign I'd cringe, but now its, "No problem.  I got that."
I just can't say enough how much this has improved functionality.
This one and the CAMotics integration plug-in have saved me tons of headaches.
« Last Edit: November 18, 2016, 15:53:29 pm by Bob La Londe » Logged
« Reply #38 on: January 09, 2017, 20:10:55 pm »
Update attached here http://www.cambam.co.uk/forum/index.php?topic=6138.msg48671#msg48671, version 5
Has been compiled with .NET version 4 assemblies and references to CamBam v1.0 dlls
Has been modified and tested to work on;
    Windows
    Linux
Works with CamBam version 1 ONLY
« Reply #39 on: October 29, 2018, 18:36:48 pm »
I've been getting an error lately.  Both machines I have CB installed on.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentNullException: Value cannot be null.
Parameter name: array
   at System.Array.IndexOf[T](T[] array, T value)
   at MyNamespace.Class1.Myplugin.DetermineChanges()
   at MyNamespace.Class1.Myplugin.main()
   at MyNamespace.Class1.plugin_clicked(Object sender, EventArgs e)
   at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
   at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
   at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
   at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
   at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ToolStrip.WndProc(Message& m)
   at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.7.3190.0 built by: NET472REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
    Assembly Version: 1.0.6752.168
    Win32 Version: 1.0.6752.168
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/CamBam.exe
    Win32 Version: 4.7.3056.0 built by: NET472REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
CamBam.CAD
    Assembly Version: 1.0.6752.163
    Win32 Version: 1.0.6752.163
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/CamBam.CAD.DLL
CamBam.Geom
    Assembly Version: 1.0.6752.161
    Win32 Version: 1.0.6752.161
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/CamBam.Geom.DLL
System.Xml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Design
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Design.dll
Microsoft.GeneratedCode
    Assembly Version: 1.0.0.0
aligner
    Assembly Version: 1.2.0.0
    Win32 Version: 1.2.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/plugins/aligner.dll
CamBam.CAD.Solids
    Assembly Version: 1.0.1.0
    Win32 Version: 1.0.1.0
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/plugins/CamBam.CAD.Solids.dll
CamBamLathe
    Assembly Version: 1.1.6752.170
    Win32 Version: 1.1.6752.170
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/plugins/CamBamLathe.dll
CamBamPlus_Toolkit
    Assembly Version: 1.1.6752.168
    Win32 Version: 1.1.6752.168
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/plugins/CamBamPlus_Toolkit.dll
cb2cm
    Assembly Version: 1.5.1.0
    Win32 Version: 1.5.1.0
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/plugins/cb2cm.dll
CentreLines
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/plugins/CentreLines.dll
corner
    Assembly Version: 1.1.0.0
    Win32 Version: 1.1.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/plugins/corner.dll
CutViewer
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/plugins/CutViewer.dll
EntityReplace
    Assembly Version: 5.0.0.0
    Win32 Version: 5.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/plugins/EntityReplace.dll
ExcellonIO
    Assembly Version: 1.5.6752.175
    Win32 Version: 1.5.6752.175
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/plugins/ExcellonIO.dll
ExtrudeSolids
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/plugins/ExtrudeSolids.dll
Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.7.3056.0 built by: NET472REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
HeightMapPlugin
    Assembly Version: 1.3.6752.166
    Win32 Version: 1.3.6752.166
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/plugins/HeightMapPlugin.dll
NumMove
    Assembly Version: 1.2.0.5
    Win32 Version: 1.2.0.5
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/plugins/NumMove.dll
OneSlice
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/plugins/OneSlice.dll
ProfileCarve
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/plugins/ProfileCarve.dll
Revolved_Extrude
    Assembly Version: 3.0.0.0
    Win32 Version: 3.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/plugins/Revolved_Extrude.dll
Snappy
    Assembly Version: 8.6.0.0
    Win32 Version: 8.6.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/plugins/Snappy.dll
Snap_ToolbarAddins
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/plugins/Snap_ToolbarAddins.dll
TextOnPolyline
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/plugins/TextOnPolyline.dll
ThreadingMOP
    Assembly Version: 1.5.6205.27600
    Win32 Version: 1.5.6205.27600
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/plugins/ThreadingMOP.dll
trochomops
    Assembly Version: 2.1.2.0
    Win32 Version: 2.1.2.0
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/plugins/trochomops.dll
ViewToolbarAddins
    Assembly Version: 1.0.6204.36853
    Win32 Version: 2.6.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/plugins/ViewToolbarAddins.dll
OpenTK
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/OpenTK.DLL
Accessibility
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Microsoft.Vsa
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.8922
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.Vsa/8.0.0.0__b03f5f7f11d50a3a/Microsoft.Vsa.dll
Antlr4.Runtime
    Assembly Version: 4.5.0.0
    Win32 Version: 4.5.3.0
    CodeBase: file:///C:/Program%20Files%20(x86)/CamBam%20plus%201.0/Antlr4.Runtime.DLL
System.Web
    Win32 Version: 4.7.3160.0 built by: NET472REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
System.Data
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Drawing.Design
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.Design.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
« Reply #40 on: October 29, 2018, 19:47:44 pm »
I just tried the plugin and it worked okay, can you provide a cb file or instructions how to replicate the error ?
« Reply #41 on: October 30, 2018, 00:17:47 am »
I just try to use the plugin normally.
https://youtu.be/ll1GO90jN0M
« Last Edit: October 30, 2018, 00:25:38 am by Bob La Londe » Logged
« Reply #42 on: October 30, 2018, 11:14:20 am »
Bob, give this new version a try.
Updated version attached here; http://www.cambam.co.uk/forum/index.php?topic=6138.msg48671#msg48671
I don't know if the code in CamBam has changed but it looks like the problem occurred when there was no Boundary ID specified in the 3D MOP. I can't believe this wasn't tested in previous versions though  Huh
« Last Edit: October 30, 2018, 11:21:29 am by EddyCurrent » Logged
« Reply #43 on: October 30, 2018, 16:33:32 pm »
I'll try it in just a little bit.  I recently figured out a way to CAM and cut molds faster using a taller mesh (cutter radius taller works really well) above Zero and setting stock surface to zero.  This gives me the best tool path coverage of the cavity, constrains it to the cavity, and basically takes one major step and one minor step to CAM.  I just select the mesh, and select the style.  Done.  No creating boundaries.  No second mesh just for boundary creation.  Allows me to use a stepover factor, and I still get full retraction to zero on every pass without having to retract and rapid from end to start.  No selected shapes needed.  Just Boom done.  Takes minimal more planning in CAD and saves tons of time in CAM.
It never occurred to me the new method of doing CAD/CAM was the problem.  Thank you.
I'll try it right now.
« Reply #44 on: October 30, 2018, 16:36:41 pm »
BOOM!  Fixed!
THANK YOU!
Pages: 1 2 [3] 4
Page created in 0.171 seconds with 19 queries.
