April 25, 2019, 12:45:36 pm
Pages: 1 ... 4 5 [6] 7 8 9
Author Topic: 'Simulate with CAMotics' plugin  (Read 33077 times)
« Reply #75 on: February 16, 2017, 11:45:44 am »
I try the mac version (camotics_1.1.0_x86_64.pkg) and it works very good.
The old version don´t show the material while simulation, only at the end.
This version makes a update of the view at the end of every line.
I install the windows 32bit version camotics_1.1.0_x86.exe on a windows 7 drive without problems. Between the installation it installs a Microsoft Visual C++ 2015 package.
I install the windows 64bit version camotics_1.1.0_AMD64.exe on a windows 7 drive without problems. Also here between the installation it installs a Microsoft Visual C++ 2015 package.
« Last Edit: February 16, 2017, 11:53:31 am by pixelmaker » Logged
« Reply #76 on: February 16, 2017, 11:58:24 am »
Hello Ralf
Yes, same for me .. I'll retry maybe a corrupted file ? (or it won't XP !)
« Reply #77 on: February 16, 2017, 11:58:52 am »
Hello Ralf
Yes, same for me .. I'll retry the download ; maybe a corrupted file ? (or it won't XP !)
« Reply #78 on: February 16, 2017, 12:01:10 pm »
1 minute please, XP is starting
The installation on XP works without problems. When I start camotics I get the same warning "This is not a valid win32 application"
Same with the Debug Version. It looks that this software don´t work with XP
« Last Edit: February 16, 2017, 12:15:37 pm by pixelmaker » Logged
« Reply #79 on: February 16, 2017, 13:01:39 pm »
Ok, I retry too, and same result ...
so return to 1.06
« Reply #80 on: February 16, 2017, 19:58:09 pm »
I am running Windows XP Pro 32 that is currently registry hacked to look to Microsoft like Windows XP Embedded for POS and I am not having any issues with XP and Camotics or the plug-in.  I am not using the latest version of the Plug-In however.  Still using CB 098P.
FYI:  Windows XP Embedded for POS is Windows XP Pro SP3 at its core.
« Reply #81 on: February 16, 2017, 20:26:17 pm »
I tried this trick, but with no luck  Angry
https://github.com/CauldronDevelopmentLLC/CAMotics/issues/194
(XP Pro SP3)
« Reply #82 on: March 14, 2017, 12:43:00 pm »
Added version 1.5.1 to the first post.
* mop-specified tools are allowed (same as in 1.5)
* mop-specified tool with index 0 is valid now (will issue a warning though).
handy for small jobs with a single non-library tool and no toolchanges
GeoffreyGRoy
« Reply #83 on: April 14, 2017, 00:55:24 am »
I have noted a small issue in the naming of the saved NC file.  Normally, and correctly, the name of the NC file created matches the name of the CamBam file.  I have a case where the name of the NC file matches the name of one of the MOP entries!  This may not be a plugin issue but rather something to do with my CamBam model, any thoughts?
Geoff
« Reply #84 on: April 14, 2017, 13:45:57 pm »
I haven't been following this thread since I own a licensed copy of CutViewer  Mill.  Are there any advantages to Camotics over Cutviewer that would incent me to switch?
« Reply #85 on: April 14, 2017, 14:34:51 pm »
I also use CV, but sometimes I use Camotics because it is able to save the result as STL ; CV can't
« Reply #86 on: April 17, 2017, 14:26:49 pm »
Can you provide a test file with the issue ?
I call CAMUtils.GenerateGCodeOutput(CamBamUI.MainUI.ActiveView);
and think cambam does the same then clicking Produce Gcode.
« Reply #87 on: April 18, 2017, 01:31:57 am »
Produce Gcode when right clicked on MOP names output like this.
« Reply #88 on: April 18, 2017, 02:18:36 am »
CB will accept MOP names with characters that are not valid for file names.
GeoffreyGRoy
« Reply #89 on: April 20, 2017, 00:15:17 am »
Dear JK
The example Cambam file is rather large and cannot be posted, but I can attach a pdf doc showing some steps in the process.
I also note that is the NC files exists and "Cancel" is selected  on the file dialog then the plugin continues and will try to load a previously created NC file into Camotics.  Maybe this is intentional.
Geoff
* Examples using Camotics Simulate.pdf (344.1 KB - downloaded 116 times.)
Page created in 0.169 seconds with 19 queries.
