January 16, 2019, 07:38:50 am
Pages: [1] 2 3 ... 9
Author Topic: 'Simulate with CAMotics' plugin  (Read 29793 times)
« on: September 13, 2016, 20:30:10 pm »
Hi !
Had some free time and rewrote my 'CAMotics export' python script as a plugin.
It will add a new entry to the Tools top menu. Single click on a 'Simulate with CAMotics' will regenerate G-code file,
create CAMotics xml project with embedded tools and stock definitions and (re)open it in CAMotics.
Source on github:
https://github.com/jkmnt/cb2cm
Feedback is welcome )
Version 1.5.1 - mop-specified tools are allowed now
Version 1.4 - fix for the diameter of conical tools
Version 1.3 - fix calculation of length for the conical tools, added warnings for tool diameter conflicts
Version 1.2 - fix for spaces in file path
Version 1.1 - changed nc paths in xml to relative
* cb2cm_1_5_1.zip (7.93 KB - downloaded 164 times.)
« Last Edit: March 14, 2017, 12:40:25 pm by jk » Logged
« Reply #1 on: September 13, 2016, 21:15:47 pm »
Sounds great, I'll give it a try tomorrow.
« Reply #2 on: September 13, 2016, 21:36:51 pm »
Neat!  New plugin creation has been at a lull for a time.  Maybe your effort will stimulate it again.
(I'm one of the guilty)
« Reply #3 on: September 13, 2016, 21:41:47 pm »
Just tried the plugin and it works very good. Thanks for that.
 As you say it creates Xml project file. Often wonder why would I want the xml project file.. As far as I'm concerned it is useless feature, because all I need to see/verify how machined part will looks like and CaMotics does this with out creating an xml file.. Wink
« Last Edit: September 14, 2016, 11:57:52 am by Bubba » Logged
« Reply #4 on: September 14, 2016, 10:35:52 am »
Excellent job, works fine for me and have not come across any issues/bugs with it so far  Cheesy
« Reply #5 on: September 14, 2016, 17:18:56 pm »
I try this plugin. Because CAMotics is installed at a different drive (camotics nativ on mac, windows in a VM) I get the message:
"Failed to run CAMotics. Set location in cb2cm.config file or start CAMotics manually before CamBam to autodetect it."
If I start CAMotics before CamBam it don´t autodetect it, because the different drive. I don´t see cb2cm.config.
If I open the .xml file in CAMotics I don´t see any toolpath.
The path in the .xml file is <nc-files>Y:\Desktop\testcode1.nc</nc-files>. This path is wrong because the .nc file is at the same location then the .xml file.
If I change the path manually to  <nc-files>testcode1.nc</nc-files> I can open the file in CAMotics and all works.
I think the path must always be the only the filename, without storage path. NC file and XML file are always at the same place and it needs no absolute path.
« Reply #6 on: September 15, 2016, 12:14:57 pm »
Thank you all for testing.
The xml project is for passing information absent in g-code to the CAMotics. Now it is a table of used tools, stock dimensions and sim resolution. Maybe a something else in the future as the CAMotics will develop.
If there are a tooltables synced between CB and CM, and correct stock size is of no interest, .nc will suffice )
Regarding the error:
I doubt one could launch native app (external to to vm) from the virtual machine.
cb2cm.config is stored in CamBam's system folder (Tools->Browse System Folder).
Upon CB startup, plugin tries to detect CM executable in location specified in config, else looks in some common locations (Program Files ...), else tries to find a running windows process named 'camotics' and determine the path it was started from. Detected location is stored in config for the next run.
e.g. my config entry is <camotics_path>D:\winp\app\camotics\camotics.exe</camotics_path>
Thanks for suggestion of pathless .nc files - it is a right way. Fix will follow )
« Reply #7 on: September 15, 2016, 12:28:36 pm »
That's exactly where I'm at...  Wink
« Reply #8 on: September 16, 2016, 03:21:48 am »
Updated initial post with version 1.1
« Reply #9 on: September 16, 2016, 09:42:52 am »
in xml to relative
Thank you,
now it works also if the files are on different drives
dwc
« Reply #10 on: September 16, 2016, 10:29:38 am »
Thanks for your work making this plugin!
I have not been using CAMotics as I am too lazy to make those project files, now all is automatic, great!
« Reply #11 on: September 16, 2016, 17:59:10 pm »
Just played with your plug-in.  THAT'S COOL.
It created the XML and the G-Code just fine.
Then it opened CAMotics.
Then I had to open the project file manually.
The results were good and dead easy compared to anything else I've done.  This is cool.
« Reply #12 on: September 16, 2016, 18:08:51 pm »
I'm not sayin' that Bob "has sway" with me, but when he says something is "cool", I listen.
First chance I get, I'll be trying this out, too!
joel.r1
« Reply #13 on: September 17, 2016, 14:34:09 pm »
All working fine, except it does not (re)open in CAMotics... CAMotics open, but is empty Angry
If I open the .xml file manually, then working fine.
CB files and .nc are not stored in default CB directory, but on USB stick. May be the reason.
Any idea ?
Cheers. Joel.
« Reply #14 on: September 17, 2016, 16:52:07 pm »
I tried it and had the same result.  It did not open the XML file automatically.  I didn't really care.  The rest worked so well that little bit wasn't even annoying to me.  My NC files and CB files are each stored in a separate folder per customer and customer project, so I might have the same issue.
Page created in 0.162 seconds with 19 queries.
