June 16, 2019, 21:42:33 pm
Author Topic: drag knife  (Read 2964 times)
« on: September 05, 2016, 19:31:03 pm »
Hi !
Sharing a fun little project - drag knife holder. It uses a common utility blade, which could
be flipped for different offsets, 1.65mm and 4mm. Small offset is for fine contours
and thin materials, big offset is for the thick stuff.
Note: do not expect a perfomance of cutting plotter (or cardboard cutter with a motorized knife) :-)
The bearings are 19x6x6 mm (626). Shaft is made from old endmill with oversized shank, made a nice
pressfit.
Bearing mount design is pretty lame but simple.
One should fill the gap between the body and the bearing clamp with spacers/shims.
Proper fill will form the solid assembly, make a tight fit for a bearing, yet not deform/overtight it.
Otherwise there would be too much friction for a proper knife tracking.
Machined from 8mm alu plate on a hobby-grade desktop router. Used two endmills (6mm and 3mm) and a very
shallow passes (0.6 mm) + wd-40 for anti-sticking.
* jk_drag_knife.cb (142.77 KB - downloaded 187 times.)
chuckeroo
« Reply #1 on: September 30, 2016, 03:01:44 am »
Well sir I have interest! And if you have this finished and it appears this is the case. Share the code!!! What the heck I would use it And enjoy it. Had a look at Doneck's site for pricing something like $230.00 Ouch. Thanks for any help you can offer.
« Reply #2 on: September 30, 2016, 07:12:14 am »
Donek was a source of ... hmm ... inspiration :-)
Source is there - cambam project is attached next to the pictures, maybe you'd missed it ?
chuckeroo
« Reply #3 on: September 30, 2016, 12:13:42 pm »
Ouch . Need to put my glasses on more often.
« Reply #4 on: September 30, 2016, 16:57:20 pm »
Just thought an original sketch in dxf may be useful.
Attached here.
* jk_knife_sketch.dxf (200.64 KB - downloaded 141 times.)
niner_zero
« Reply #5 on: June 24, 2018, 04:21:40 am »
Nice work. Simple too.
Page created in 0.126 seconds with 19 queries.
