January 21, 2020, 21:04:52 pm
Author Topic: Lathe tutorial or workflow with roughing and finishing. G70 G73 approximations  (Read 2748 times)
helmholtz
« on: April 26, 2016, 18:23:04 pm »
I used up my 40 evaluations before I ever got Cambam to output the gcode I was looking for and was hoping for some advice from those that use cb for a 2 axis lathe before I by a license for software that I haven't gotten to work for me.
First, I'm very comfortable writing gcode by hand so I know that what I'm getting from cb isn't correct. I would typically use G70 and G73 cycles to cut a profile, however I use Mach3 on my home cnc machine and it doesn't support canned profiling cycles, hence my need for software like cb.
I've used this tutorial: http://www.cambam.info/doc/plus/cam/Lathe.htm
My biggest issue is that I don't understand the workflow required to generate both roughing and finishing passes for the same profile and the above tutorial skips over that crucial explanation.
Is there a tutorial somewhere that shows step by step how to generate the roughing mop and then how to make the finishing mop using the same original profile line? I end up with very inefficient results when trying this, so I know that I missing something, and probably something simple.
thanks in advance!
« Reply #1 on: April 26, 2016, 19:18:59 pm »
Roughing and finishing mop
https://www.youtube.com/watch?v=JR8TlrxmE78
helmholtz
« Reply #2 on: April 27, 2016, 03:23:38 am »
Thank you! That video had exactly what I needed. I knew it was a simple workflow issue.
Thanks for the help.
Page created in 0.084 seconds with 19 queries.
