January 22, 2018, 23:50:53 pm
Pages: 1 ... 3 4 [5]
Author Topic: Spiral Toolpath from Profile  (Read 13021 times)
« Reply #60 on: November 21, 2016, 06:53:09 am »
I'm almost ready for another update so wait until then, I'll have a look at the translation code.
« Reply #61 on: November 21, 2016, 17:18:17 pm »
New version attached (v4.0)
1. Removed from Plugins menu, can now be found in top menu, Draw->Profile To Helix
2. Includes hogging out roughing toolpaths
3. Undo points added
4. pdf manual
Translation should work but I'm sure David will let me know otherwise  Cheesy
Please report back with any problems found.
* Profile2Helix_v4.0.zip (10.82 KB - downloaded 61 times.)
* Profile2Heliix.pdf (823.91 KB - downloaded 88 times.)
« Last Edit: November 24, 2016, 08:56:28 am by EddyCurrent » Logged
« Reply #62 on: November 23, 2016, 22:43:51 pm »
Hello Eddy
I just install the last version
translation is working  Wink
a little problem remain, the menu item text must never be translated (except if you creates your own form with menu) ; if it is translated it appears twice in the translation list ( item and !item) when we use the "flag untranslated" option in the translation plugin (and appears as !!item in the menu)
I've also other unwanted entries that appears in the translation list for some times, but currently I'm not able to know what plugin is responsible ... I must investigate.
edit: I just show a tippo error in "Tool Diameter"  the first "e" is missing in both roughing and finishing
« Last Edit: November 23, 2016, 23:02:01 pm by dh42 » Logged
« Reply #63 on: November 24, 2016, 08:57:38 am »
Thanks for that, I've just replaced the two files.(same version number)
newlinuxuser
« Reply #64 on: November 27, 2016, 22:48:30 pm »
Hello, I would just  report that the last working version in linux is the 1.0.
New versions cause the closure of cambam.
Andrea
« Reply #65 on: January 09, 2017, 20:33:59 pm »
Update attached, version 5
Has been compiled with .NET version 4 assemblies and references to CamBam v1.0 dlls
Has been modified and tested to work on;
    Windows
    Linux
Works with CamBam version 1 ONLY
* Profile2Helix_v5.zip (11.19 KB - downloaded 58 times.)
« Reply #66 on: January 12, 2017, 23:57:59 pm »
Hello Eddy  Wink
On both version, sometimes the plugin generate roughing toolpath even if the checkbox is disabled.
- run the plugin
- check the roughing box
- close without creating toolpath
- re open the plugin > the roughing box is not checked but if you generate TP, you get the roughing TP.
I think the pb is only with the roughing checkbox that is not updated to the saved value when the form is opened.
Also, I don't know if it's a bug or the way the plugin is working, but if I try to do shape with few points (to do a square or a triangle) there is small strait lines aligned on the X axis like on the picture in attachment.
« Last Edit: January 13, 2017, 00:05:30 am by dh42 » Logged
« Reply #67 on: January 13, 2017, 12:24:34 pm »
Thanks once more your your excellent testing  Grin
version 5.1 attached
Both issues should be okay now.
* Profile2Helix_5.1.zip (11.21 KB - downloaded 59 times.)
« Reply #68 on: May 23, 2017, 15:59:41 pm »
New version 6 attached
This allows resulting toolpath helix lines to be copied to a specified 'Group' of objects.
Please see here for the main reason behind this; http://www.cambam.co.uk/forum/index.php?topic=6614.msg53330#msg53330
Obviously it also requires the Groups plugin to be installed; http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/Groups.html
I've modified this as quick as possible so please report any bugs etc.
* Profile2Helix_v6.zip (11.96 KB - downloaded 49 times.)
« Reply #69 on: May 23, 2017, 16:37:05 pm »
Eddy, it's for CB V0.98 or for V1.0 ?
« Reply #70 on: May 23, 2017, 16:38:44 pm »
v1.0
« Reply #71 on: June 09, 2017, 20:53:15 pm »
Version 7 attached
One for CamBam v1.0, one for CamBam 0.98
Added a dropdown so users can select accuracy (tolerance), the lower the number the longer will be the calculation time.
The value is not units dependant so the same accuracy will apply to both mm and inches.
Edit: attachments removed, see later post for new version
« Last Edit: August 09, 2017, 10:04:56 am by EddyCurrent » Logged
« Reply #72 on: August 09, 2017, 10:03:42 am »
Updated version attached, should work with CamBam 0.9.8 and 1.0
1. Translation code fixed
* Profile2Helix_v7.1.zip (12.2 KB - downloaded 35 times.)
« Reply #73 on: August 10, 2017, 00:16:26 am »
Eddy,
Clearly you are running out of great improvements for this plugin. So how about making it sweep around shapes other than a circle? In fact if you could sweep the shape profile along just a straight line that could be useful too. One could easily cut molding and such.
« Reply #74 on: August 12, 2017, 03:53:19 am »
Ok, thank Eddy ; works ok on both versions.
Page created in 0.151 seconds with 18 queries.
