May 21, 2018, 19:50:05 pm
Pages: 1 [2] 3 4 5
Author Topic: Spiral Toolpath from Profile  (Read 15920 times)
klystron
« Reply #15 on: January 26, 2016, 14:10:35 pm »
Thank you Eddy ,
great program,
Yves
« Reply #16 on: January 26, 2016, 14:45:45 pm »
Thanks Eddy, Awesome job!
« Reply #17 on: January 26, 2016, 18:27:09 pm »
Nice idea this plugin Wink
« Reply #18 on: February 01, 2016, 10:43:31 am »
Gary, does this last version do what you wanted ? I'm currently working on adding a roughing path.
« Reply #19 on: February 01, 2016, 14:27:31 pm »
Eddy,
I haven't had a chance to try it but I will.
« Reply #20 on: February 07, 2016, 00:20:12 am »
hello
Added to the website
http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/Spiral2helix.html
« Reply #21 on: October 24, 2016, 15:56:33 pm »
I use the spiral2helix plug-in a lot. A really nice improvement would be tool radius compensation, inside or outside maybe by positive or negative offset. This plug-in gets used with the Engrave MOP but the cut is nearly always a profile needing the offset.
This week we are using it to threadmill a 3/4" tapered pipe thread. Material is PVC, so relatively easy job, however there are 40 holes so CNC makes sense.
(topic merged)
« Last Edit: October 24, 2016, 16:24:18 pm by dh42 » Logged
« Reply #22 on: October 26, 2016, 14:54:37 pm »
Gary,
I had a play about with adding this at the time but could not get a satisfactory solution.
For example, imagine you created a profile similar to a bowl about 3" deep and 6" diameter.
First you would have to clear all the waste from inside with roughing cuts, then make a finishing cut with tool radius offset.
So, having made the first spiral I tried using 'Scale' to make progressively smaller spirals to the centre, that's no good because scale won't work like that for these shapes. 'Offset' worked to a point but not ideal.
For now can I suggest you draw the profile shape required then make an 'Offset' line inside to compensate for tool radius, then create the spiral from that line.
I can only assume that by using an Engrave MOP your equipment can handle cutting to the full depth of the spiral in one pass.
Edit: I might have a new Alpha Test version done this week if I can get the code back in my head.  Huh
« Last Edit: October 26, 2016, 15:14:02 pm by EddyCurrent » Logged
« Reply #23 on: October 26, 2016, 15:10:16 pm »
I tried doing an offset and all I got has a flat arc.
Seems more like you need to plan the line that generates the helix to account for cutter diameter.
If using a .5" thread mill and wanting to cut a thread that tapers from 1.0" to 0.875"  You would need to draw a line from (0.375,0.0) to (0.50,(+y)).   Or rather (.5,0 to .375,(-y).
If you want to sneak up on it you would then need to draw a couple more lines steps in towards zero from the first.
The next issue you run into is accounting for the fact that your thread won't be right if you use the bottom of the thread mill as zero.  The point of the flutes needs to be z=0 to get your tapered thread right.  I'd go further as to say like regular thread milling you need to start (or finish more likely) above the stock and add a tag to the bottom of the helix to avoid a crash.  Of course the hole needs to be deeper than you plan to thread by atleast half the thickness of the thread flutes vertically.
« Last Edit: October 26, 2016, 15:56:12 pm by Bob La Londe » Logged
« Reply #24 on: October 26, 2016, 15:14:35 pm »
Can you attach your cb file ?
Here's one I just tried;
* example.cb (426.66 KB - downloaded 70 times.)
« Last Edit: October 26, 2016, 15:22:54 pm by EddyCurrent » Logged
« Reply #25 on: October 26, 2016, 15:23:36 pm »
I've modified my previous post.  No I was just doing some experiments.
I read your previous past as doing an offset from the drawn helix.  That doesn't work.  That generates a flat arc.  If you make an offset from the original line, and use that to generate the helix then it works.
I have to add that the vertical flute thickness can be accounted for instead by setting depth and depth increment to half the vertical thickness of the flutes, and them the bottom of the tool can be zero.  Probably easier to keep track of it that way.
« Last Edit: October 26, 2016, 15:29:14 pm by Bob La Londe » Logged
« Reply #26 on: October 26, 2016, 15:46:16 pm »
I'll have to think about that for a while  Huh
« Reply #27 on: October 26, 2016, 15:54:23 pm »
Sorry, Eddy.  I don't think your plug-in needs to be modified for that.  I was adding that to help Gary with making sure he doesn't destroy parts.  If using the helix for thread milling then the point needs to be level with the helix.  Not above it or below it.  In this case I think only a single point (1 or multiple flute) thread mill would do the job.
It is not after all a thread milling MOP plug-in, but a helical geometry creating plugin.
« Reply #28 on: October 26, 2016, 16:00:52 pm »
It only works for concave shapes such as bowls etc.
Try this version.
WARNINGS
1. it might break tools or spoil the work piece until further testing, however results appear okay on a simulator
2. it might(will) not work for profiles approaching vertical or horizontal at any point.
3. accuracy may be an issue for the finishing cut.
4. Even though the MOPs are partly populated some parameters need user input and all checking before use.
@David (dh42) please do not add this to the Plugin web page yet  Wink
Edit: file removed pending update
« Last Edit: October 28, 2016, 13:05:47 pm by EddyCurrent » Logged
« Reply #29 on: October 26, 2016, 16:36:46 pm »
I will look at it, but I think I can make the first version work for tapered thread milling.  Inside or outside.  Just have to account for all those pesky details.
~~~~~  OH!  ~~~~~
I just realized the problem.  The increment is along the line.  Neither vertical nor horizontal isn't it?
In order to use it for thread milling you need to do a little trig to get the proper increment.
« Last Edit: October 26, 2016, 16:45:54 pm by Bob La Londe » Logged
Pages: 1 [2] 3 4 5
Page created in 0.261 seconds with 18 queries.
