January 22, 2018, 23:52:38 pm
Pages: 1 [2] 3 4 ... 6
Author Topic: Dotted Lines reborn as "Dashed Lines"  (Read 17121 times)
« Reply #15 on: May 31, 2015, 14:32:50 pm »
Ah yes, linestyle 2 is prettier  Wink
Currently adding more line styles  Cheesy
« Reply #16 on: May 31, 2015, 14:34:29 pm »
THAT's weird.  I posted to that thread, immediately after reading the comment about delayed responses from the child processes.
Hmm.... I'll re-post.
« Reply #17 on: May 31, 2015, 14:39:03 pm »
Lloyd, maybe you were behind by one and didn't flush the pipe ?  Grin
« Reply #18 on: May 31, 2015, 19:56:22 pm »
New version added to first post v4.
1. new line styles
2. new menu
Just need Bubba to give it the thumbs up now  Cheesy
« Last Edit: May 31, 2015, 20:07:52 pm by EddyCurrent » Logged
« Reply #19 on: May 31, 2015, 20:47:27 pm »
When I find the time to test it you will see it.. I'm sure. Wink Cheesy Grin
My 2
« Reply #20 on: June 01, 2015, 10:52:57 am »
Updated file added to first post v5
1. It is now possible to use the mouse double click method to edit a DotPolyline.
Just double click on the line to enter edit mode.
« Reply #21 on: June 01, 2015, 12:36:53 pm »
Good addition  Cheesy
The double click to edit dotpolyline is not working for me ...  Huh
The form and its content is not translatable.
We can't use a value > 10 for spacing in the Form, but the properties grid accepts value > 10 (and the drawing reflect this value) ... it's a wish or a oblivion ?
« Reply #22 on: June 01, 2015, 13:06:13 pm »
I will remove all other plugins from my folder in case another one is helping it.
How do we translate Label text ? is translation required for this plugin ?
Fixed, file updated on first post.
Edit: I just removed all other plugins and it still works okay.
Are you just double clicking on the line as you would to edit a regular polyline ?
« Last Edit: June 01, 2015, 13:11:45 pm by EddyCurrent » Logged
« Reply #23 on: June 01, 2015, 13:46:49 pm »
Ok, I'll do the same to test ... and I'll also take a try on my W7 insta that still use Pbeta2 (I use the very last P on XP pro) and I go back ..
to add the texts in the forms to the translation list you need:
- a 't' char in the Tag property of each label/button/container that must be translated , (and also in the Form tag property)
- a function with the same name as the form that contain the command to translate the form ( just after the InitializeComponent() )  (static void Translate(Form f))
Now, I have to leave, but I can watch it in the evening, if you want, send me the code and I take a look ; I think I can do it even If it's in C#  Wink
http://www.cambam.co.uk/forum/index.php?topic=3553.msg29394#msg29394
http://www.atelier-des-fougeres.fr/Cambam/Aide/API%20Doc/Cambam_cad_dll/Cambam_Utils/textTranslation.html
« Reply #24 on: June 01, 2015, 14:18:22 pm »
edit dotpoly with dbl click work on W7 + Pbeta2 ... I'll investigate further to know if it is related to Windows or to the CB version .. or other plugin installed ...
« Reply #25 on: June 01, 2015, 17:07:02 pm »
Translation code added to form.
I had a go with the translation plugin, this was the result  Cheesy
new version v6 added to first post.
« Last Edit: June 01, 2015, 17:24:00 pm by EddyCurrent » Logged
« Reply #26 on: June 01, 2015, 18:01:10 pm »
Ok, that looks OK
I'll test tomorrow .... no mind to do that now  Cry
« Reply #27 on: June 01, 2015, 18:10:10 pm »
No problem, sorry to hear about your cat, I'll bet it was a good companion  Sad
« Last Edit: June 01, 2015, 20:52:21 pm by EddyCurrent » Logged
« Reply #28 on: June 02, 2015, 16:25:44 pm »
Ok the pb is not related with the Win version nor the CB version, the double click to edit Dot Polylines stop working if I translate the name of the entity itself (the name that appears in the tree)
« Reply #29 on: June 02, 2015, 16:54:23 pm »
There is a problem with the translation ; the items to translate are added 3 time in the list.
1 - the english key to translate
2 - the same with the '!' in front
3 - the translated text is also added as a key.
Page created in 0.118 seconds with 18 queries.
