August 20, 2019, 19:58:12 pm
Pages: 1 ... 3 4 [5]
Author Topic: Fillet-Chamfer plugin  (Read 23245 times)
Mark81
« Reply #60 on: February 24, 2019, 13:29:59 pm »
Hello! Two thoughts about this useful plugin:
  • It seems the value inserted is the radius of the circle used to calculate fillet/chamfer. Sometimes I need to have a chamfer of a given with (in other word I know the length of the chord itself. I can do the math manually but it requires to know the length of the chord (ok) and the height. For a newer version, might I suggest to add a checkbox to select whether the value is the radius or the chord's length?
  • I don't understand how what a negative value should do, nor how to restore/change a corner that has already modified with a fillet. In other CAD I use it's enough to change the value and click again in the same position to change it. With your plugin what is the recommended method?
Thanks a lot for your work!
« Reply #61 on: February 24, 2019, 15:47:46 pm »
Be sure to get the latest version here; http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/fillet-chamfer.html
A negative value gives a convex corner, useful for nameplates, etc.
To restore a modified corner use Ctrl+Z (Undo)
Mark81
« Reply #62 on: February 24, 2019, 15:53:43 pm »
I meant not immediately, but any time later.
« Reply #63 on: February 24, 2019, 16:01:07 pm »
You may be asking too much ...
« Reply #64 on: May 06, 2019, 05:52:16 am »
An existing arc can't be changed with the plugin, you can only add new arcs on corners. (if I well understand what you wanted)
@Dragon: working 3 hours this night to try to make it working on Linux, and no way ... and I don't understand why  Huh ... sorry
« Reply #65 on: May 06, 2019, 12:45:31 pm »
Argh ! I think it's now working on linux ... it took 6 hours more to get it working!
@dragon: can you test the version in attachment ?
should works on V0.98 and V1.0, (only for Linux version )
* LinuxRadiusPlugin.zip (15.99 KB - downloaded 23 times.)
« Reply #66 on: May 07, 2019, 13:36:06 pm »
Works OK. Thanks, David!
« Reply #67 on: May 07, 2019, 20:26:28 pm »
Nice !
It is a 64 bit version of Linux ?
Some things that I can't solve is different behaviors than on Windows ; on Linux I must click one time in the drawing windows or in the plugin window to obtain the display of the small square at the mouse pointer. Also I can't remove the "close" button in the plugin windows, so I change the code a little so this button do the same than ESC key and exit the plugin.
Another thing ; to be able to move the plugin window, I also must click in the "working area" of the plugin window first to be able to move it ; if I just click in the title bar, that do not activate the windows and I can't move it.
« Last Edit: May 07, 2019, 20:29:30 pm by dh42 » Logged
« Reply #68 on: May 07, 2019, 20:37:14 pm »
Yes, 64-bit Ubuntu 16.04.
I'll check what you describe. While testing previous time  I didn't notice unusual behavior of the small rectangle pointer.
« Reply #69 on: May 07, 2019, 22:00:08 pm »
Ok, I tested it on Ubuntu 14.04 LTS 32 bit on a laptop ... and often, I've video problem with linux on this machine ; seems it don't like my CAD VGA board ... sometime I get "blue screen" or "patchwork" on the display and I must reboot the PC (but it works perfectly with Windows  Grin)
Page created in 0.151 seconds with 19 queries.
