June 16, 2019, 14:09:33 pm
Pages: 1 2 [3] 4 5
Author Topic: Fillet-Chamfer plugin  (Read 22124 times)
« Reply #30 on: August 31, 2016, 19:27:02 pm »
Bubba,
The only CamBam related stuff you will find in there are plugins that save their settings to the Registry, anything else will not be in there.
« Reply #31 on: August 31, 2016, 19:43:21 pm »
Hello Bubba
I have really no idea about why the keys for this plugin are not in the registry ; if they are missing, they are created when the plugin is run for the first time and a default position for the windows is set to X = 300px, Y = 60Px from the top-left angle.
Maybe a pb with W10 ? (can't test, I have only XP and 7)
If you can't solve your pb, I can compile a special version for you that do not use registry, just to test.
in CB can you set the "diagnostic level" to 4, then try to run the plugin and look in the log window if there is any error message.
« Reply #32 on: August 31, 2016, 19:54:26 pm »
This may be the answer,
The window only appears if you have first selected a polyline, I tried it with a polyrectangle and the window did not appear.
« Reply #33 on: August 31, 2016, 20:27:18 pm »
Hum, yes, maybe I can add an alert if no polyline is selected ...
« Reply #34 on: August 31, 2016, 20:36:45 pm »
Thanks Eddy and David for the reply's. As it turn out Eddy's last suggestion did the trick. After exploding the polyrectangle I joined the adjacent polylines and was able to use the plugin here, it worked fine! Shot down CamBam, checked the registry and sure enough the entry key for the Radius Plugin show up.. Grin
Thanks guys for your advice.  Wink
« Reply #35 on: August 31, 2016, 20:39:37 pm »
David, I think it would be good idea. Wink
This one and Numerical Move are one most used by me plugins. Thank you for creating them.
« Reply #36 on: August 31, 2016, 20:48:30 pm »
done  Grin
http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/fillet-chamfer.html
« Reply #37 on: August 31, 2016, 20:57:30 pm »
just do CTRL + P to convert any 2D object to polyline (even a point list or a text) Wink no need to explode/join.
(= menu: edit/convert/to polyline)
« Last Edit: August 31, 2016, 20:59:12 pm by dh42 » Logged
« Reply #38 on: September 01, 2016, 00:34:05 am »
Thank you.
michel
« Reply #39 on: April 22, 2017, 16:53:39 pm »
I am using this plug in regularly and it would be nice if a fillet could be added on multiple selected items. I usualy have between 20 and 25 parts on 1 sheet that needs to be machined. As most of the parts have to fit in another part i use the corner overcut function to allow a nice fit but mostly not al corners needs to be overcut so my workaround is just to add a filet of 0.01 in the corner which I do not want any overcut. When running the toolpath you can see that the corner-overcut is skipped on these points. So that is great but time consuming as the plug in only works on 1 selected part at the time. Is there any chance to get this update for multiple selected parts ?
regards
Michel
« Reply #40 on: April 22, 2017, 17:01:14 pm »
The built in Fillet command works on multiple selected objects.
michel
« Reply #41 on: April 22, 2017, 17:41:45 pm »
Hi Eddy
yes but as I mentioned some shapes have corners that does not need overcut and some needs overcut . Thr built in command puts a fillet on all corners.
It should work like the plug in version so that I can select the ones that needs a fillet. And this on a multiple selection level.
« Reply #42 on: April 22, 2017, 20:40:09 pm »
Topic merged
It's not a bad idea ; I'll see if I can do that when I will works on a new release.
michel
« Reply #43 on: April 22, 2017, 22:02:18 pm »
Hi David,
Thanks for that  Smiley
Do you have any timeframe on this so that I can keep it alive  Grin
regards
Michel
« Reply #44 on: April 22, 2017, 22:16:17 pm »
No, not at all ! .. I program only for the pleasure, when I've the inspiration, the time, an interest for the project ..etc .. so it's really unpredictable !  Grin
And of course, sometimes that won't works as I want and I stall on the project ..  Embarrassed
Pages: 1 2 [3] 4 5
Page created in 0.157 seconds with 19 queries.
