May 21, 2018, 19:26:13 pm
Pages: 1 2 3 [4] 5
Author Topic: SCRIPT SUMMARY  (Read 34247 times)
« Reply #45 on: May 24, 2015, 21:52:53 pm »
Thanks for the texts Wink
Select the polyline object so it's highlighted (one object only) one or multiple objects can be selected
I reload the last version and I can't select more than one polyline ; if it's the case I get a message box 'Please Select One Item Only'
David, sorry, sorry, it's the ghost of Dotted lines haunting me. It was the dotted lines I changed not the Polyline Add Points. It is still one object only so nothing to change.
« Reply #46 on: May 24, 2015, 22:12:02 pm »
 Grin Grin
« Reply #47 on: May 30, 2015, 14:48:02 pm »
Dashed lines added
« Reply #48 on: June 08, 2015, 20:27:35 pm »
File Cleaner, Zoom to toolpah extent and Tangent added.
« Reply #49 on: June 24, 2015, 23:08:43 pm »
hello David,
I see that you start to set the downloadlinks from this list to a direct download at your atelier-des-fougeres.fr-website.
I think that this is not the best way. Only if you make updates to this site we can find the update.
Today I look for the last version of the v-engrave plugin. This afternoon I download the "VEngrave_Plugin Vb0008.zip". Now I download from your site a "VEngrave_Plugin.zip".
I can´t jump to the thread. I have to go to atelier-des-fougeres.fr and from there back to the CB forum. This makes only traffic, but no sense.
I have no more version controle. Please leave this list as it is, with the direct links to the thread and the download.
Add a additional link to atelier-des-fougeres.fr-website.
Where is this "VEngrave_Plugin Vb0008.zip" and why is this a different version then this from the thread, there I found a "v-engrave-plugin-latest.zip". What is the latest version.
edit
CAMToolbarAddins
Thread: http://www.cambam.co.uk/forum/index.php?topic=4569.0
Download: http://www.cambam.co.uk/forum/index.php?action=dlattach;topic=4569.0;attach=11625
« Last Edit: June 24, 2015, 23:19:42 pm by pixelmaker » Logged
« Reply #50 on: June 24, 2015, 23:43:01 pm »
Hello Ralf,
It's the same.
I maintain the web site up to date with the latest version of the plugins
The plugin itself is also stored on my website, and I use a name that is always the same and that is not dependent of the version (if I use a name with a version number, I need the redo the link each time in the page)
The version number/date is written in the second line in the array on the web page, and of course, you can know the version number just by puting the mouse under the dll in your windows folder
http://www.cambam.co.uk/forum/index.php?topic=3513.msg27789#msg27789
The reason is maybe because pstmarie stop the development with version b0005 and then, Lloyd continue up to 0008 ... the latest IS 0008 ; the "v-engrave-plugin-latest" is the latest done by pstmarie, but bot the latest version that exists.
When the web site will be finished, I'll remove the list on the forum (no sens and too much job to maintain both)
david
« Reply #51 on: June 24, 2015, 23:46:54 pm »
re,
I don't understand your edit with CAMToolbarAddins ?
« Reply #52 on: June 25, 2015, 00:10:13 am »
I can´t find them in your list.
The latest version from pstemari/v-engrave-plugin is from 16. September 2013.
The latest v-engrave plugin (from lloydsp) is the 008 from 10. März 2014.
In your download is not the latest version.
While I search for this here in this forum I found also the CAMToolbarAddins, what should have a link from the plugin. And I found the tutorial from bob for making Inlay with the plugin and the inlay calculator. All those links that correspond with the plugin are lost now.
« Reply #53 on: June 25, 2015, 00:23:50 am »
It's the latest version on the web site ; V 0008 - 10 March 2014 ; look the pictures
CamToolbarAddin is in CAM tool / Custom CAM Toolbar
I have not modified anything for inlay calculator ; it's always at the same place  Huh picture3
« Last Edit: June 25, 2015, 00:30:20 am by dh42 » Logged
« Reply #54 on: June 25, 2015, 11:08:37 am »
Hello David,
what I mean is that it will be better to let the links from the script and plugin page direct to the thread and download.
it's not just that you have a lot of work and constantly must update links. There is also a lot of unnecessary traffic to and from your own site.
jimmer
« Reply #55 on: August 18, 2015, 15:52:54 pm »
These look interesting. Unfortunately the first 2 I've tried don't appear on my menu.  Do plugins work with the evaluation version?  I'm using 0.9.8.
The 2 i've tried are Polygon and Squircle.
The toolkit involute gear is there under plugins.
Cambam. Mach3. USB motion controller. 1800x950 ballscrew router, vacuum bed, 3kW spindle.
« Reply #56 on: August 18, 2015, 16:03:05 pm »
Jimmer,
Many of the plugins create new icons on the toolbar, and don't necessarily appear in the drop-down menus.
When a plugin is installed in the plugins folder, you must re-boot CB to cause it to recognize the new material.
So far as I know, the trial version does not restrict their use, but some plugins are only for certain release versions. 0.9.8 should be expected to work with most of them, but not all.
« Reply #57 on: August 18, 2015, 16:05:38 pm »
Yes, but only if you have not exceeded the 40 uses, after 40 uses, the plugins are disabled.
« Reply #58 on: August 18, 2015, 16:20:09 pm »
Ah... yes!  I forgot that.
Perhaps he's past his usage limit.
jimmer
« Reply #59 on: August 18, 2015, 19:31:36 pm »
edit:  All working now. Thanks for the squircle, just what I needed.
« Last Edit: August 18, 2015, 19:46:19 pm by jimmer » Logged
Pages: 1 2 3 [4] 5
Page created in 0.358 seconds with 18 queries.
