February 18, 2020, 10:21:45 am
Pages: 1 ... 14 15 [16] 17 18
Author Topic: V-Engrave Plugin  (Read 135811 times)
« Reply #225 on: December 15, 2016, 19:32:17 pm »
V-Engrave still won't work but neither does Threadmill and Trochoidal Pocket.
All those work by adding a new type of MOP so there is something common there.
« Reply #226 on: December 15, 2016, 19:41:42 pm »
Strange, trocho pocket works as a charm on the V1.0 for me  Huh Huh and also Threadmill .. except that on V1.0 the toolpath are missing on the display for Threadmill  (but the gcode is ok)
and ... no pb to use the same file with 0.98 and v1.0 ...
« Reply #227 on: December 15, 2016, 22:29:24 pm »
tried to recompile Vengrave with some debug text to find what is going wrong.
the error seems to appears at this line (in AttachToUI)
new XmlSerializer(typeof(MOPVEngrave)).Serialize(new MemoryStream(), new MOPVEngrave());
but ... I do not understand what is it and what it do .. Huh
« Reply #228 on: December 15, 2016, 22:33:45 pm »
This is the error message.
Other plugins work okay.
« Reply #229 on: December 15, 2016, 22:36:34 pm »
 if (CADFile.ExtraTypes == null)  { CADFile.ExtraTypes = new List<Type>(); }
 CADFile.ExtraTypes.Add(typeof(MOPVEngrave));
  // HACK: Per 10bulls, this fixes clipboard errors associated with
 // copying external assembly objects that have not been serialized.
« Reply #230 on: December 15, 2016, 23:05:39 pm »
wait a minute, I found the pb and it seems to works !  Cool Cool
« Reply #231 on: December 15, 2016, 23:31:43 pm »
Ok, V engrave repaired, now it works on both 0.9.8 and and V1.0  Cool
http://www.atelier-des-fougeres.fr/Cambam/Aide/Plugins/Vengrave.html
@ Eddy:
recompiled with .net 3.5 as usual (and of course .98 dll)
I only replace a statement and it works !
in plugin.cs
 close to line 230
[XmlType("MOPVEngrave"), Serializable]
is fully replaced by
[Serializable]
              foreach (TreeNode opNode in partNode.Nodes)
                    if (opNode.Tag == mop)
                        mop.Name = opNode.Text;
                        opNode.EnsureVisible();
                        break;
                    break;
        foreach (var smop in CamBamUI.MainUI.CADFileTree.SelectedMOPs)
            ThisApplication.AddLogMessage("SelectedMOPs: {0}", smop.Name);
    //[XmlType("MOPVEngrave"), Serializable]
    // dh42: changed with [Serializable] so it works with V1.0
    [Serializable]
    public class MOPVEngrave : MOPFromGeometry, IIcon
    // Smallest number such that 1.0 + DBL_EPSILON != 1.0
    const double DBL_EPSILON = 2.2204460492503131e-016;
    // Radians per degree
    const double DEGREES = Math.PI/180.0;
    // Log levels
    const int ERROR = 0, WARNING = 1, INFO = 2, DEBUG = 3, TRACE = 4, FINE = 5, FINER = 6, FINEST = 7;
    // logger
maybe something to test with dashed line plugin  Grin Grin (Makes a prayer !)
you know what ? I'm happy  Cheesy
« Last Edit: December 15, 2016, 23:41:51 pm by dh42 » Logged
« Reply #232 on: December 16, 2016, 00:09:04 am »
it's me again  Grin
I've a try with dotpolyline with replacing [XmlType .... ] by [Serializable] no change ...
on 0.9.8, error when loading plugin, and error when saving the file
on 1.0, no error when loading the plugin or saving the file, but error "UnKnow entity type: DotPolyline" when loading.
 Embarrassed Embarrassed
good night
« Reply #233 on: December 16, 2016, 02:36:32 am »
As Always, an awesome job David. The VEngrave plugin working like a champ in CB V1. Much appreciated. Thanks.
« Reply #234 on: January 08, 2017, 11:05:20 am »
New version 12 attached
1. compiled with .NET 4
2. works with CamBam version 1 only
3. works in Windows and Linux
Thanks to David for the [Serializable] fix  Grin
* VEngrave_Plugin_v12_CamBam_v1.zip (22.51 KB - downloaded 223 times.)
« Last Edit: January 08, 2017, 11:10:58 am by EddyCurrent » Logged
michel
« Reply #235 on: January 09, 2017, 15:19:40 pm »
I tried the plug in and it works very well . However I have 2 issues
I cannot setup camotics to run the simulation with a v-cutter . It seems to only use round shapes even if i try to change it in camotics directly
second issue is that this is taking a lot fo memory . How can I reduce the g-code and still keep a decent result ?
my cnc memory is limited to 31.5 K . For stairs more then enough but not for such issues and it happens that I need it for a project .
I can manage it with the engrave plug-in and this one already pushing the limit of the memory. I just want to try to see if the v-engrave gives a better result.
regards
Michel
« Reply #236 on: January 09, 2017, 19:20:17 pm »
Maybe you can play with Path Step Size to reduce the number of Gcode line .. if you increase this value, you get few lines in the toolpath.
kitwn
« Reply #237 on: March 06, 2017, 05:16:06 am »
I was starting to think I would need to spend$460AUD on V-Carve to be able to produce the text carvings I want to make. That's a lot of money for something that is just a hobby.
Then a second round of CamBam related searching took me to the 'atelier-des-fougeres' website and there I found the goldmine!
Not just V-Engrave, which works perfectly with my DIY, LinuxCNC driven router, but a whole host of other really useful plugins. A very big THANKYOU! to everyone who's efforts make CamBam even better than it already is.
Kit
« Reply #238 on: March 06, 2017, 22:47:59 pm »
Welcome to the forum Wink
kitwn
« Reply #239 on: March 07, 2017, 06:04:41 am »
Thankyou David,
I've been using CamBam for various simple jobs for a couple of years now but haven't paid much attention to the forum until very recently. It has certainly paid off in the last few days.
Kit
Page created in 0.166 seconds with 19 queries.
